I've only recently started using Captivate and I'm interested in re-desigining some of the assessments we do. It seems as though the quiz functionality only really copes with text, and I was wondering if it's possible for them to be a bit more interactive.
For example, I would like to insert this image into a quiz and ask them to name the individual parts, does anyone know if this is possible or could come up with a work-around? I thought of maybe doing something with Hotspots but it's not ideal.
Any advice would be greatly appreciated.
Cheers
Shaun
This would work OK with a Drag and Drop interaction where the learner is required to drag text captions to their correct locations on the image (or to the ends of the lines that point into the image).
Yes, it can be done, but it is not a newbie work flow because you'll have to use variables and advanced or shared actions.
Quite a while ago (would be easier now with later versions of CP) I created this example for a colleague professor:
Link score to attempts in Custom questions - Captivate blog
Watch the included movie (it is Flash, you need a desktop/laptop with SWF enabled browser).
I would not use hotspot question in this case, but did you think about using Drag&Drop and have the names dragged to the proper locations? Be aware if this is a 'question' to be scored, you cannot have partial scoring in that case because the default setup for a validated D&D is all correct or it is esteemed incorrect.
