5 Replies Latest reply on Sep 18, 2016 1:16 PM by Loic.Aigon
    list item backgroundcolor
    scriptworker Level 1
      Hello,
      I'd like to set the backgroundcolor of a listitem
      in a listbox. Is that possible? If yes, how can it
      be done?
      Kind regards,
      Michel
        • 1. Re: list item backgroundcolor
          tpk1982 Level 4
          something like this?
          var w = new Window ("dialog");
          var myList = w.add ("listbox");
          for (var i = 1; i < 5; i++) {
          myList.add ("item", "Line_" + String (i));
          myList.graphics.backgroundColor = myList.graphics.newBrush (w.graphics.BrushType.SOLID_COLOR, [0.5, 0.0, 0.0]);
          myList.graphics.foregroundColor = myList.graphics.newPen (w.graphics.PenType.SOLID_COLOR, [1, 0.5, 0.5], 1);
          myList.preferredSize = [100,100];
          w.show ();
          • 2. Re: list item backgroundcolor
            Thank for the answer. I am almost there.
            I want to set the background of each item
            separately. Is that possible?
            Kind regards,
            Michel
            • 3. Re: list item backgroundcolor
              I've read through the forum about this.
              Seems to be extremely difficult to get
              a per item background color in a listbox.
              Michel
              • 4. Re: list item backgroundcolor
                I've finally found a solution I can work with.
                I've abandoned the listbox. I am using panels now.
                With many thanks to Peter Kahrel and his ScriptUI pdf.
                Michel
                w = new Window('dialog');
                w.maximumSize.height = 300;
                var panel = w.add ('panel {alignChildren: "left"}');
                var scrollGroup = panel.add ('group {orientation: "column"}');
                for (var i = 0; i <= 5; i++)
                  item_ = scrollGroup.add ('group {orientation: "column"}');
                  text_ = item_.add('statictext', undefined, 'Label ' + i);
                  item_.addEventListener('click',function()
                       removeBackgrounds();
                       this.graphics.backgroundColor = this.graphics.newBrush (this.graphics.BrushType.SOLID_COLOR, [1, 0.0, 0.0]);
                var scrollBar = panel.add ('scrollbar {stepdelta: 20}');
                // Move the whole scroll group up or down
                scrollBar.onChanging = function () {
                scrollGroup.location.y = -1 * this.value;
                w.onShow = function() {
                // Set various sizes and locations when the window is drawn
                panel.size.height = w.size.height-20;
                scrollBar.size.height = w.size.height-40;
                scrollBar.size.width = 20;
                scrollBar.location = [panel.size.width-30, 8];
                scrollBar.maxvalue = scrollGroup.size.height - panel.size.height + 15;
                w.show();
                function removeBackgrounds()
                  for (var j=0; j<scrollGroup.children.length; j++)
                  scrollGroup.children[j].graphics.backgroundColor = scrollGroup.children[j].graphics.newBrush (scrollGroup.children[j].graphics.BrushType.SOLID_COLOR, [0.94, 0.94, 0.94]);
                • 5. Re: list item backgroundcolor
                  Loic.Aigon Adobe Community Professional
                  For what it's worth, this group/list trickery may fail to display every single group of the serie. For example, if the counter is higher than 34, then all the groups from 35 to n won't be displayed (it may vary depending on screens sizes and settings). But at some point it fails.
