9 Replies Latest reply on Sep 19, 2016 4:28 AM by Obi-wan Kenobi
    GREP find paragraph style
    jakec88782761 Level 2
      Hi guys,
      I'm using this grep to find all words that use the Body text paragraph style.
      However I get the same result whether I specify a paragraph style to find or not.
      The result is always the same. Why is this?
      app.findGrepPreferences=null;
      var found = app.findGrepPreferences.findWhat="\\b\\w+?\\b";
      found.appliedParagraphStyle="Body text";
      found=app.activeDocument.findGrep();
      alert("This document has "+found.length+" words");
      gives the same result as
        • 1. Re: GREP find paragraph style
          TᴀW Adobe Community Professional & MVP
          You're not doing it quite right:
          app.findGrepPreferences = null;
          app.findGrepPreferences... etc. (this is fine, but you don't need to assign the found variable yet, it achieves nothing to do so)
          app.findGrepPreferences.appliedParagraphStyle = app.activeDocument.paragraphStyles.itemByName("Body text"); // Could be that you can use your shortened form, but I always do it the long way, so I know exactly what's happening. Also, for para styles in Groups it's necessary.
          found = app.activeDocument.findGrep();
          etc.
          Ariel
          Edit: Specifically, in your line beginning var found =, you have actually assigned to the found variable the string "\\b\\w+?\\b", NOT app.findGrepPreferences.findWhat, which it looks like you were trying to do...
          • 2. Re: GREP find paragraph style
            Hi Ariel,
            when I run this code:
            this line returns an error - "invalid value for set property 'appliedParagraphStyle'. Expected string, paragraphStyle but received nothing.
            • 3. Re: GREP find paragraph style
              tpk1982 Level 4
              Make sure your style is not within any group, otherwise we need to give the group name in the coding
              • 4. Re: GREP find paragraph style
                The style may be in a group (as tpk1982 mentions). But also check your spelling and capitalization carefully. The name must be 100% exact. The style must exist in the document already, of course.
                • 5. Re: GREP find paragraph style
                  Obi-wan Kenobi Level 5
                  Hi!
                  app.findGrepPreferences = app.changeGrepPreferences = null;
                  app.findGrepPreferences.findWhat = "\\b\\w+?\\b";
                  app.findGrepPreferences.appliedParagraphStyle = "Body text";
                  or
                  About the op's question: it gives the same result because there's no other para style applied than "Body text"!
                  • 6. Re: GREP find paragraph style
                    tpk1982 Level 4
                    Yes, TaW and (^/) both are correct with logic.. but if the OP give the screenshot of paragraph style palette then problem is solved
                    • 7. Re: GREP find paragraph style
                      Body text is within a group called body. How can I include this in my code?
                      • 8. Re: GREP find paragraph style
                        tpk1982 Level 4
                        app.findTextPreferences.appliedParagraphStyle=app.activeDocument.paragraphStyleGroups.item ByName("body").paragraphStyles.item("Body Text");
                        • 9. Re: GREP find paragraph style
                          app.findGrepPreferences.appliedParagraphStyle=app.activeDocument.paragraphStyleGroups.item("body").paragraphStyles.item("Body text");
