6 Replies Latest reply on Sep 17, 2016 6:11 PM by mauricior6328708
    [AppleScript] Target Photoshop CC 2015.5?
    DBarranca Level 4
      I'm doing a bit of AppleScript automation and I'm completely stuck at square one.
      This works flawlessly:
      tell application "Adobe Photoshop CC"
        do javascript file ("/Users/davidebarranca/Desktop/pippo.jsx")
      end tell
      (if you wonder, pippo.jsx just alerts "PIPPO")
      This breaks miserably (merely added 2015.5):
      tell application "Adobe Photoshop CC 2015.5"
      end tell
      With the following error: Syntax Error – Expected end of line but found identifier.
      And it selects the "javascript" word.
      I've been banging against this wall for one hour – what the heck is happening?!
      I've tried to run this script in the Terminal:
      sleep 5; osascript -e 'tell application "System Events"' -e 'set frontApp to name of first application process whose frontmost is true' -e 'end tell'
      You run it, then you have 5 seconds to switch to Photoshop, and then Terminal will log the Application name, which is – guess what – "Adobe Photoshop CC 2015.5".
      So why on earth those 3 lines of applescript are wrong?! They're driving me nuts :-)
      Thank you,
      Davide Barranca
        • 1. Re: [AppleScript] Target Photoshop CC 2015.5?
          pixxxel schubser MVP & Adobe Community Professional
          Hi Davide,
          in [JS] you can call the version Photoshop CC2015.5 with
          #target photoshop-100.064
          or more simple
          For CC2015 you need
          #target photoshop-90.064
          or more simple
          Perhaps you can do the same in Applescript? I don't know.
          Have fun
          • 2. Re: [AppleScript] Target Photoshop CC 2015.5?
            maxwyss Level 4
            I am doing quite a few (Photoshop) JavaScript calls out of Applescript, and I explicitely state that it is a POSIX file, and I also set the file spec in parentheses. Your example would then look like this:
              do javascript (file (POSIX file ("/Users/davidebarranca/Desktop/pippo.jsx")))
            end tell
            and this is stable.
            If Photoshop CC 2015 is not installed when CC 2015.5 is present, I can even tell the application "Adobe Photoshop CC 2015" to do stuff, and it will do that correctly.
            • 3. Re: [AppleScript] Target Photoshop CC 2015.5?
              DBarranca Level 4
              Thanks for your replies, my comments below:
              pixxxel schubser: the AppleScript way is exactly 'tell application "AppName"'. In fact for "Adobe Photoshop CC" the little script works flawlessly.
              maxwyss: I've tried adding POSIX, but no luck. By the way, using "Adobe Photoshop CC" without POSIX works fine anyway, so it should "Adobe Photoshop CC 2015.5"
              Let's reformulate with a simpler code:
              # Working
                do javascript "alert('boo')"
              end tell
              and:
              # Broken
              end tell
              What the heck is going on there?!
              Davide
              • 4. Re: [AppleScript] Target Photoshop CC 2015.5?
                DBarranca Level 4
                I've been able to track the root cause of the issue – not been able to solve it, though.
                I can't run AppleScript invoking Photoshop versions that I also happen to have in my Parallels virtualized Windows 10.
                So to speak, Parallels "steals" them from OSX.
                In fact, if I:
                set doesExist to false
                try
                  do shell script "osascript -e 'exists application \"Adobe Photoshop CC\"'"
                  set doesExist to true
                end try
                return doesExist
                It returns TRUE; while if:
                try
                  do shell script "osascript -e 'exists application \"Adobe Photoshop CC 2015\"'"
                end try
                return doesExist
                It returns FALSE. Countercheck:
                set appID to id of application "Adobe Photoshop CC"
                is "com.adobe.photoshop", while:
                set appID to id of application "Adobe Photoshop CC 2015"
                is "com.parallels.winapp.ba6ce4f563fc495390502afab876d865.e76675ef6e5847ae8f396c55f9ff2f09"
                So I'm currently unable to use CC 2015 and CC 2015.5 via AppleScript because they're sort of missing, because "stolen" by Parallels.
                I've contacted their tech support – I hope they'll be able to tell me how to set things back to normality – has anyone of you ever had to do such a thing?
                Thank you in advance,
                Davide
                • 5. Re: [AppleScript] Target Photoshop CC 2015.5?
                  DBarranca Level 4
                  Problem solved.
                  Recap: I'm using Windows 10 virtualized with Parallels Desktop on my Mac, and Windows has "stolen" some Photoshop versions (the one I've installed also on the PC side) from OSX – that's the reason why AppleScript fails: it can't find Photoshop.
                  Solution: I had to disable application sharing:
                  Probably I could leave "Share Mac applications with Windows" on, but I don't need it anyway.
                  I hope this is going to save some hours-thrown-down-the-toilet to somebody else in the future.
                  Davide
                  • 6. Re: [AppleScript] Target Photoshop CC 2015.5?
                    mauricior6328708 Level 1
                    I do not use mac ... But I think here hundreds of users use and sure enough, it will be useful to many. Thank you for sharing Davide.
