4 Replies Latest reply on Sep 19, 2016 8:33 PM by Roei Tzoref
    Masking issue
    mountc43503757
      I am trying to mask around a hockey player, and I'm trying to change the background around him, I drew a mask around the player, the background behind him went blank, because there was no layer under it, there is a gap between his arm and his hip where I can see the original background, I've tried making another mask on that layer, nothing worked, I've tried to duplicate the mask layer and delete the mask on the new duplicated layer, and add a separate mask around the area with the original background, it didn't work, I tried switching the modes to subtract many different ways, can someone help please?
        • 1. Re: Masking issue
          Reorder your mask and use the Intersect mode. Simply keep trying. The mask modes logic is sometimes odd - when it should be add, it's often subtract and vice versa. Otherwise pre-compose the main mask and apply your otehr mask on the resulting pre-comp layer.
          Mylenium
          • 2. Re: Masking issue
            Roei Tzoref Adobe Community Professional
            a screenshot would help a lot here for us to give you the right workflow and suggestions. please post it.
            if you are planning to do some rotoscoping you should read the following links thoroughly first. this is important and even vital to create convincing composite because 90% good job won't cut it with roto work.
            for mask roto:
            Managing and animating shape paths and masks in After Effects
            Use alpha channels, masks, and mattes in After Effects
            Modifying and using views in After Effects
            for other method of rotoscoping you should consider RotoBrush:
            Roto Brush and Refine Matte in After Effects
            In general about mask roto, a good practice would be sometimes to set and adjust you mask in the layer panel and not the composition panel. you set both open side by side and this way you can have it both ways - see the composite, and adjust your mask comfortably in a separate window. you can utilize the various layer view modes. these are similar to refine edge in Ps (now found in the "select and mask" taskspace). you can also uncheck the render box to see your image and mask it too without the mask being rendered. another advantage for this method is that you won't accidentally move your layer.
            • 3. Re: Masking issue
              mountc43503757 Level 1
              Screenshot 2016-09-19 20.47.06.pngScreenshot 2016-09-19 20.47.21(2).pngOnly the mask around the player works, I tried clicking subtract next to mask two, or even darken, but it just stays the same under his armpit, I'm just trying to use the pen tool on this one.
              • 4. Re: Masking issue
                yes. this should work. I can't really see you have two masks on the same image here.
                make sure you follow these steps because looking on your screenshots, I can't be sure:
                • if mask1 is Add - it means it will cut your image from you background
                • if mask 2 is Subtract it will subtract from the mask above it
                • both masks need to be in the same layer
                • both masks need to be closed
                • mask order is important
                Darken/Lighten are for intersecting masks so no use for you here.
                BTW I am not sure why you are masking a still image so carefully in Ae, or is this auto trace? anyways, you should know that if it's a still image, and if the path is not supposed to animate, you have much better tools for creating selections of stills in Photoshop. Also, this will save you the render time for calculating the mask in Ae.
