1 Reply Latest reply on Sep 18, 2016 9:20 AM by johnrellis
    Very slow editing (spotting) problem
    dougl10216408
      I am trying to eliminate hundreds (thousands?) of mosquitoes from an image. Lightroom moves slower and slower the more edits I complete. It is now virtually frozen. Each additional "spot" can take 30 seconds or longer. Can someone explain what is happening and how I can eliminate this problem so I can complete my editing process?
      Doug LeClair
        • 1. Re: Very slow editing (spotting) problem
          johnrellis Most Valuable Participant
          It's a well-known, long-standing issue with LR: The more local adjustments you do with the adjustment brush and the spot-removal tool, the slower LR will go.  At some point, as you discovered, it just crawls.  These tools weren't designed to do more than a relatively small number of adjustments -- if you need more, Photoshop is a better choice (as you've discovered).
