7 Replies Latest reply on Sep 19, 2016 1:37 AM by Roei Tzoref
    Trouble Previewing
    morganj15002101
      Hi..I am currently having trouble previewing my layers in After Effects. Some of the layers are Pre-composed, so I'm not sure if it has something to do with that. When I try to preview or render my animation it's only shows whatever color the composition is. It seems like its not playing the pre-composed comps.
        • 1. Re: Trouble Previewing
          Roei Tzoref Adobe Community Professional
          in this case a screenshot is worth a thousand words. show us what's wrong exactly and make sure your full Ae interface is visible.
          • 2. Re: Trouble Previewing
            morganj15002101 Level 1
            I'm not sure if this issue has to do with my graphics card warning.
            • 3. Re: Trouble Previewing
              first let's deal with this message:
              you probably need to turn of your composition ray-tracing feature. go to composition->composition settings->advanced and change it to "Classic 3D" not see if you are seeing your composition correctly. if this did not fix your issue let's examine your project.
              in this screenshot:
              you are in a comp called :
              watching a precomp placed inside called:
              your CTI is at 06:19. we don't know what's inside this precomp. when you click on it twice what do you see inside at 06:19? it should be the same thing.
              • 4. Re: Trouble Previewing
                Hey, thanks for getting back so fast. My composition settings was already set to "classic 3D." When I double click the pre-comp, it goes to another composition with a few layers and another pre-comp. I'm not to sure what CTI is...my animation is only 2:30 - 3:00 minutes long so far.
                • 5. Re: Trouble Previewing
                  Also the animation will show up if its not rendered fully. Once I start scrubbing through the timeline, or once its fully rendered that's when I'm not able to view the animation
                  • 6. Re: Trouble Previewing
                    CTI - current time indicator - that blue line that tells you where you are in time and you see it move all the time.
                    too many questions to ask here. you got a project here that has precomps inside precomps and it could be anything really. upload your project (just your aep file) and I will take a look. use any cloud service
