1 Reply Latest reply on Sep 18, 2016 4:48 PM by Polycontrast
    Photoshop CC and Bridge CC
    Polycontrast Level 1
      I like to ask the members that understand Bridge CC scripting if the following idea can be accomplished with a Bridge/Photoshop script.
      (I am aware the contextual menu offers the menu option to Open With listing the the different Photoshop versions. This works but is slow.)
      The problem:
      Working with two different Photoshop CC versions.
      The solution:
      Create a UI dialog that displays different versions of Photoshop.
      The UI dialog is called with the return key after the Bridge thumbnails are selected.
      The idea:
      Create the UI dialog that allow the user to input the appropriate Photoshop Version to use with the selected images in Bridge.
        • 1. Re: Photoshop CC and Bridge CC
          This BR script opens files in the default version of Photoshop.
          Is it possible to edit the default version for an earlier version of Photoshop in the script?
          app.bringToFront();
          if( BridgeTalk.appName == "bridge" ) {
              var batchStack = new MenuElement( "command","Script Shell", "at the end of Tools" );
            // if photoshop is not currently running, launch it
            if ( BridgeTalk.isRunning("photoshop") == false ) {
               BridgeTalk.launch("photoshop", "background");
            var image = app.document.selections[0].path;
                var bt = new BridgeTalk;   // create new BridgeTalk message object
                   bt.target = "photoshop";   // send this message to Photoshop
                   // the script to send to photoshop
                   bt.body = "var file = new File('" + image + "');" +
                      "var docRef = open(file);" +
                      "var myx = docRef.width.toString();" +
                      "var myy = docRef.height.toString();" +
                      "var md = {x:myx,  y:myy};\r" +
                      "md.toSource();";
                   //For the result, use eval to reconstruct the object
                   bt.onResult = function(resObj) {
                      BridgeTalk.bringToFront("bridge");
                      md = bt.result = eval(resObj.body);
                      // Now you can access fname and fsize properties
                      //alert(md.x + " / " + md.y);
                bt.send();   // send the message
