0 Replies Latest reply on Sep 18, 2016 6:47 PM by Serpent
    I need a programmer to make a script (or plugin, ideally) that would allow me to nominate the width of a wine label and the diameter of the bottle it needs to fit, so that I get an isometric result.  Using 3D in PS is way too complicated for this.
    Serpent Level 1
      The solution would deliver an isometric image of a label wrapped onto a cylinder; where the inputs are:
      Enter the width of the label in mm....
      and...
      Enter the diameter of a cylinder in mm.
      I would then manually place the resulting isometric image onto my blank wine bottle.  Then manually add warping for top and bottom edges to give it camera-perspective.
      The output isometric image needs to be PNG, because the labels are often non-rectangular...and so I need to preserve transparency in the non-solid areas.
