• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Microphone won't show up in Connect
Explorer ,
Sep 18, 2016 Sep 18, 2016
I'm taking a German course through the Goethe Institute, and they use Adobe Connect for live sessions.  I'm using a Microsoft Surface Pro 3, running Windows 10.  When I'm in Connect, I get the little green  window up in the upper left corner for the speakers, but not for my microphone.  When I go through the audio setup within Connect, I can choose either the Surface microphone array, or my Logitech USB headset microphone, and it works fine with the tests.  However, after successfully going through the Connect audio tests, the microphone still doesn't show up in the program.  I've tried logging out and logging back in, with no change.  I've tried restarting the computer, with no change.  I can go into the Sound settings in Windows and choose either microphone and either the headset speakers or the computer speakers, and all work fine in Skype and the Windows recorder.  I just can't seem to get a microphone to work in Connect!  Any suggestions?
Views
13.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Sep 20, 2016 Sep 20, 2016
To test, you just need to have someone from the organization you are working with who is enabled to start meetings join a room with you. Should only take about 1 minute to validate whether or not you get microphone rights in the room. To me it sounds like you have already tested and verified that everything is working as expected.
It is also worth mentioning that you won't have access to broadcast your audio over VoIP if you are at the Participant role in a room. Only Presenters and Hosts can bro
Votes
Translate
Translate
Explorer ,
I might have a follow-up question here - I'm not seeing the microphone when I go into Connect with no one on the other end.  Does that make a difference?  Does the instigator of my meeting have to somehow enable my microphone for it to show up on my end?
Votes
Translate
Translate
Report
Report
LEGEND ,
Sep 19, 2016 Sep 19, 2016
Based on your description it sounds like they are using the licensing model, which requires a meeting host to be present. If you enter the room without someone who has the licensing to unlock the full functionality of the room, you will not be able to use VoIP audio.
So, yes, the meeting instigator must be present to enable you to use the microphone.
Votes
Translate
Translate
Report
Report
Explorer ,
So I suspect there's no way to test this without being in an actual session?
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
It is also worth mentioning that you won't have access to broadcast your audio over VoIP if you are at the Participant role in a room. Only Presenters and Hosts can broadcast audio. If Participants are given the rights to broadcast over VoIP by the Host, then they will see the mic button appear at the top of the room.
Votes
Translate
Translate
Report
Report
