4 Replies Latest reply on Sep 20, 2016 6:44 AM by Heimdaal
    Open JSON file and parse it? (ExtendScript)
    Heimdaal Level 1
      I know that JSON isn't built into ExtendScript but even with the downloaded lib I do not understand how you are supposed to use this?
      If I try and use #include in my jsx-file the entire script comes to a halt (nothing gets loaded)
      main.jsx
      #include "../js/libs/json2.js"
      alert("this does not trigger! - script halted on line above");
      So what's the approach here? Send the file path from JS to JSX, create a file object and read every line in JSX, returing the file string back to JS and then parse it?
        • 1. Re: Open JSON file and parse it? (ExtendScript)
          DBarranca Level 4
          I understand that you're referring to an HTML Panel context, am I correct?
          If this is the case, yes, include will not work. You have to send the extension's path down to the JSX from the JS, then evaluate json2.js with $.evalFile().
          From that point onwards, the JSON object should be available to your extendscript context.
          Davide Barranca
          • 2. Re: Open JSON file and parse it? (ExtendScript)
            CodeARoni Level 1
            If you want to parse JSON in extendscript, you can use a polyfill. Here's an easy example you can copy/paste: generator-gizmo/rootscript.jsx at master · codearoni/generator-gizmo · GitHub
            Just paste that at the top of you extendscript file and you should be good to go.
            • 3. Re: Open JSON file and parse it? (ExtendScript)
              Heimdaal Level 1
              I moved the parsing to the JS file instead but it appears that you can't even use JSON there! JSON is undefined -_-
              Why did Adobe make things so bloody complicated?
              EDIT
              I put the JSON.parse() inside a try-catch and I'm getting syntax errors (which is weird as I've used several online validators on my JSON code)
              Exception:SyntaxError: Unexpected token :
              JSON
                  "lolk": [
                          "icon": "/img/picA.png",
                          "path": "/scripts/file.a",
                          "text": "somethingA"
                          "icon": "/img/picB.png",
                          "path": "/scripts/file.b",
                          "text": "somethingB"
                          "icon": "/img/picC.png",
                          "path": "/scripts/file.c",
                          "text": "somethingC"
              EDIT2
              JSON.parse() seems to be completely broken?
              try{
                  var lol = JSON.parse("{'lolk':'stuff'}"); // Exception:SyntaxError: Unexpected token '
                  alert(lol);
              } catch(e) {
                  alert("Exception:" + e + "\nCould not run JSON.parse()");
              • 4. Re: Open JSON file and parse it? (ExtendScript)
                Heimdaal Level 1
                Summary
                -The JSON -library json2.js can be "included" in the main.js file by running evalFile(pathToFile). I assume this also works in JSX. Thanks goes to Davide Barranca for showing us the way!
                -You cannot use #include in the JSX file for Photoshop as this will completely break the execution
                -When reading the file, you have to do it all in one go - not line-by-line (see below).
                I read the JSON-file incorrectly, which broke JSON.parse()
                For some reason I had setup the function that did the reading, to read the file row-by-row, like this:
                JSX
                    file = new File(filePath);
                    file.open("r", "TEXT");
                    var fileString = "";
                    while (!file.eof){
                        var line = file.readln();
                        if (fileString.indexOf(line) == -1){
                            fileString += line;
                    return fileString;
                Which seems to add characters that the parser does not like.
                I changed it so that it just reads the entire file
                JSX
                    var scriptFile = File(filePath);
                    scriptFile.open('r');
                    var content = scriptFile.read();
                    scriptFile.close();
