2 Replies Latest reply on Jul 3, 2018 4:01 PM by mattp22361374
    I can't create a rasterizeOptions object in vbscript
    TomVbk Level 1
      Hi, newbie for illustrator scripting here
      I'm using vbscript because i'm used to program with this language.
      I'm trying to make a vbscript for illustrator cc that selects all content on a layer named "test" and rasterizes it with a few settings.
      I can't figure out how to use the "RasterizeOptions" class, I use vbsedit to browse trough the objects but from the moment I try:
      CreateObject("Illustrator.RasterizeOptions")
      I get the error it can't make the object? How else should I create a RasterizeOptions object?
      What am i doing wrong here, can anyone show me an example?
      Regards, Tom
        • 1. Re: I can't create a rasterizeOptions object in vbscript
          TomVbk Level 1
          I was hoping for a more quick reaction because I need this fixed on Wednesday :\
          this is my script:
          Set appRef = CreateObject("Illustrator.Application")
          Set docRef = appRef.ActiveDocument
          docref.Layers.Item("test").HasSelectedArtwork = True
          Set rasterizeOptions = CreateObject("Illustrator.RasterizeOptions") '<--- cant create activeX object!?
          rasterizeOptions.padding = 0
          rasterizeOptions.resolution = 72
          rasterizeOptions.transparency = true
          call docref.rasterize(selectedItems, selectedItems.controlBounds,rasterizeOptions)
          I hope someone can help me
          • 2. Re: I can't create a rasterizeOptions object in vbscript
            mattp22361374
            I've found Adobe to be difficult with ActiveX object.
            I now exclusively call the exact version that I want, such as
            Set aiRasterOptions = CreateObject("Illustrator.RasterEffectOptions.CC.2018")
            This seems to be much worse if you've had or have other versions of Illustrator installed on your machine.
            You can use a regdllview or something similar to see what's registered on your machine.
            HTH,
            Matt
