4 Replies Latest reply on Sep 20, 2016 3:11 AM by tpk1982
    Find punctuation using GEP
    tpk1982 Level 4
      I need to find the punctuation after italic word. I am not sure it is possible or not.
      The punctuations after red colored text need to find. Please help.
      The below GREP give all the punctuations
      (?<=\w)[[:punct:]]
      K
        • 1. Re: Find punctuation using GEP
          Peter Kahrel Adobe Community Professional & MVP
          1. Look for .[[:punct]]
          2. Iterate through the found instances: e.g.
          found = app.documents[0].findGrep();
          for (i = 0; i < found.length; i++) {
            if (found[i].characters[0].fontStyle === 'Italic') {
          Peter
          • 2. Re: Find punctuation using GEP
            tpk1982 Level 4
            Hi Peter,
            Thank you so much. Below is the finished coding. Is it okay or it will create any problem in future?
            app.findGrepPreferences = null;    app.changeGrepPreferences = null;
            app.findGrepPreferences.findWhat=".[[:punct:]]";
            alert(found.length)
                found[i].characters[1].fontStyle="Regular"
            K
            • 3. Re: Find punctuation using GEP
              Obi-wan Kenobi Level 5
              Hi Kartik,
              I'd try to be a little more vigilant and would proceed in 3 steps:
              1/ Find all occurrences of a character followed by a punctuation.
              2/ Mark [with a condition] all occurrences of a character in italic followed by a punctuation.
              3/ Check - manually - if they are valid or not.
              e.g.:
              "My great master was Yoda! I miss him!"
              vs.
              "My name is Obi-wan Kenobi! I'm a Jedi Master!"
              [to be corrected in the first case, not in the second]
              • 4. Re: Find punctuation using GEP
                tpk1982 Level 4
                Hi Obi,
                Thank you for the suggestion. My requirement is finding italic word and following punctuation, depending upon my need i may convert the punctuation as italic or regular.
                With my above code, i added a dialog box and ask the user which i need to apply.
                But my challenge for now is, sometimes the font don't contains regular style, so i decided to create a style and apply.
                like below:
                function mypunct_change(){
                var w = new Window('dialog',' Punctuation Change');
                    w.p1= w.add("panel", undefined, undefined, {borderStyle:" Punctuation Change"});
                    w.p1.add('statictext',undefined,"Select the style you want to change");
                    w.p1.g = w.p1.add('group');
                    w.p1.g.orientation = 'column'
                    w.p1.g.alignChildren = "left";
                    var mySetCheckbox = w.p1.g.add('radiobutton {text: "Regular", value: true}')
                      var mySetCheckbox1 = w.p1.g.add('radiobutton {text: "Italic"}')
                    w.p1.g1 = w.p1.add('group');
                    w.p1.g1.orientation = 'row'
                    var myOKButton = w.p1.g1.add('button {text:"OK"}')
                    var myCancelButton = w.p1.g1.add('button {text:"Cancel"}')
                var myResult = w.show()
                    if(myResult == 1){
                        if(mySetCheckbox.value==true){
                        else if (mySetCheckbox1.value==true){
                            found[i].characters[1].fontStyle="Italic"
                    else if (myResult== 2){
                      alert("You clicked Cancel!");
                      exit(0);
                K
