5 Replies Latest reply on Apr 21, 2017 12:20 PM by jpfeif
    Background Update Server - FlashPlayerUpdateService.exe deleted ?
    borisr5002947
      I'm using a background update server to upgrade our network computers (Windows 7 X64) from Flash Player 16 to 23.
      Everything works fine, client are updated fine except that FlashPlayerUpdateService.exe file is deleted after upgrade, same for the service who call this file, and for the automatic task that call the service...
      Here is my mms.cfg :
      SilentAutoUpdateEnable=1
      AutoUpdateDisable=0
      SilentAutoUpdateServerDomain=NameOfMyServerMasked
      SilentAutoUpdateVerboseLogging=1
      And here is the install log :
      =O====== M/23.0.0.162 2016-09-20+08-50-21.398 ========
      0000 [I] 00000044
      0001 [I] 00000045
      0002 [I] 00000010 FlashPlayerInstaller.exe -install -iv 9
      0003 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/23.0 2
      0004 [I] 00000011 1
      0005 [I] 00000020 C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
      0006 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
      0007 [W] 00001015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe 5
      0008 [W] 00001045 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe 5
      0009 [W] 00001015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe 5
      0010 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashUtil32_16_0_0_305_ActiveX.exe/ 2
      0011 [I] 00000013
      0012 [I] 00000015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_23_0_0_162_ActiveX.exe
      0013 [I] 00000016 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_23_0_0_162_ActiveX.dll
      0014 [I] 00000023 C:\WINDOWS\SysWOW64\Macromed\Flash\activex.vch
      0015 [I] 00000019 C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
      0016 [I] 00000021 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
      0017 [E] 00001031 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe:5
      =X====== M/23.0.0.162 2016-09-20+08-50-27.635 ========
      If I install the update manually with the msi everything works fine, and the update service still here...
      Thanks for your help.
        • 1. Re: Background Update Server - FlashPlayerUpdateService.exe deleted ?
          Destr@ Adobe Employee
          Hi
          We could not reproduce this issue, could you try uninstalling on one system and reproduce this.
          And send us exact steps to reproduce this.
          • 2. Re: Background Update Server - FlashPlayerUpdateService.exe deleted ?
            borisr5002947 Level 1
            Ok, here are the steps I'm doing to reproduce it :
            1. My test computer is now clean of any version of Flash Player, i've also deleted C:\Windows\SysWOW64\Macromed\Flash and C:\Windows\System32\Macromed\Flash folders, and registry key HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia
            2. I've disable Kaspersky Endpoint Security 10 antivirus,
            3. Manually install install_flash_player_16_active_x.msi, everything is ok (file, service, task,...)
            4. I create mms.cfg file under C:\Windows\SysWOW64\Macromed\Flash with these parameters
              AutoUpdateDisable=0
              SilentAutoUpdateServerDomain=srvsus01.hopital-saint-joseph.fr
            5. Our Background Update Server is on a IIS web server, anonymous access on,
            6. I start the update task manually, and same problem .exe disappear after a while (3mn)
            7. Here is the complete FlashInstall.log
            =O====== M/16.0.0.305 2016-09-20+12-38-03.396 ========
            0000 [I] 00000010 "C:\Users\ADMINI~1\AppData\Local\Temp\InstallAX_16_0_0_305.exe" -install -msi
            0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/16.0 2
            0002 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
            0003 [I] 00000011 1
            0004 [I] 00000020 C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
            0005 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
            0006 [I] 00000013
            0007 [I] 00000015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe
            0008 [I] 00000016 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.dll
            0009 [I] 00000023 C:\WINDOWS\SysWOW64\Macromed\Flash\activex.vch
            0010 [I] 00000019 C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
            0011 [I] 00000021 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
            0012 [I] 00000012
            =X====== M/16.0.0.305 2016-09-20+12-38-06.516 ========
            2016-9-20+12-53-54.100 [info] 1628 srvsus01.hopital-saint-joseph.fr
            2016-9-20+12-53-54.100 [info] 1629 srvsus01.hopital-saint-joseph.fr
            2016-9-20+12-53-54.101 [info] 1614
            2016-9-20+12-53-54.101 [info] 1615
            2016-9-20+12-53-54.101 [info] 1618
            2016-9-20+12-53-54.102 [info] 1619 1063
            2016-9-20+12-53-54.119 [info] 1628 srvsus01.hopital-saint-joseph.fr
            2016-9-20+12-53-54.120 [info] 1629 srvsus01.hopital-saint-joseph.fr
            2016-9-20+12-53-54.120 [info] 1614
            2016-9-20+12-53-54.120 [info] 1615
            2016-9-20+12-53-54.120 [info] 1618
            2016-9-20+12-53-54.121 [info] 1604
            2016-9-20+12-53-54.121 [info] 1608
            2016-9-20+12-53-54.126 [info] 1631 /pub/flashplayer/update/current/sau/currentmajor.xml
            2016-9-20+12-53-54.242 [info] 1630 /pub/flashplayer/update/current/sau/22/xml/version.xml
            2016-9-20+12-53-54.243 [info] 1632
            2016-9-20+12-53-54.244 [info] 1630 /pub/flashplayer/update/current/sau/22/xml/patch.xml
            2016-9-20+12-53-54.245 [warning] 1445
            2016-9-20+12-53-54.245 [info] 1632
            2016-9-20+12-53-54.245 [info] 1600
            2016-9-20+12-53-55.192 [info] 1602
            2016-9-20+12-53-55.192 [info] 1609
            2016-9-20+12-53-55.192 [info] 1612
            2016-9-20+12-53-55.193 [info] 1620
            =O====== M/16.0.0.305 2016-09-20+12-53-56.780 ========
            0000 [I] 00000010 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe -uninstall activex -msi
            0001 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
            0002 [W] 00001015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe 5
            0003 [I] 00000018
            0004 [W] 00001015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe 5
            0005 [W] 00001015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.dll 5
            0006 [I] 00000018
            0007 [W] 00001015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.dll 5
            0008 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
            0009 [W] 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
            0010 [W] 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
            0011 [W] 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
            0012 [W] 00001021
            0013 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
            0014 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
            0015 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
            0016 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
            0017 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
            0018 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
            0019 [W] 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl 2
            0020 [W] 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
            0021 [W] 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
            0022 [W] 00001036 Software\Macromedia\FlashPlayerPepper/PlayerPath 2
            0023 [W] 00001015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.dll 5
            0024 [W] 00001015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.dll 5
            0025 [W] 00001015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe 5
            0026 [W] 00001015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe 5
            0027 [I] 00000011 1
            0028 [I] 00000012
            =X====== M/16.0.0.305 2016-09-20+12-53-57.383 ========
            =O====== M/23.0.0.162 2016-09-20+12-53-55.435 ========
            0000 [I] 00000044
            0001 [I] 00000045
            0004 [I] 00000011 1
            0011 [I] 00000013
            =X====== M/23.0.0.162 2016-09-20+12-54-01.711 ========
            • 3. Re: Background Update Server - FlashPlayerUpdateService.exe deleted ?
              maria__ Adobe Employee
              Thank you for posting the log files.  This is due to permissions errors on the file system and/or registry.  The error is in the last line of the log file:
              1031 is the Flash Player error code when there are permissions issues on a file.  The number 5 is the ERROR_ACCESS_DENIED Microsoft error code.  Due to incorrect file system and/or registry permissions the file can't be created, which results in the Background Update Service Task and Service not being created.
              The Troubleshoot Flash Player install issues related to Windows registry permissions  help doc has information on fixing this, as does the FAQ How do I fix Windows permission problems with Flash Player?   The script posted here is very restrictive to Flash Player files, however, it's possible another file, indirectly used by Flash Player installer, is the cause.  If running this script doesn't work, you can try running this script from Microsoft, available at https://support.microsoft.com/en-us/kb/968003, which resets permissions on all files/registry entries in the system
              • 4. Re: Background Update Server - FlashPlayerUpdateService.exe deleted ?
                Bobobulk
                Hi m_vargas,
                I understand that it's a permissions problem, but the fix you asked to apply doesn't fix the problem.
                I've tried with others versions of Flash player, it's always the same behavior the flash player works fine, but during background update the FlashPlayerUpdateService.exe seems to be in use and cannot be update by the process.
                Same for Update task that is deleted but not created again.
                =O====== M/16.0.0.305 2017-01-30+09-04-03.866 ========
                0003 [I] 00000018
                0006 [I] 00000018
                0012 [W] 00001021
                0027 [I] 00000011 1
                0028 [I] 00000012
                =X====== M/16.0.0.305 2017-01-30+09-04-05.442 ========
                =O====== M/24.0.0.194 2017-01-30+09-04-01.074 ========
                0000 [I] 00000044
                0001 [I] 00000045
                0002 [W] 00001113 C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\* 3
                0003 [I] 00000010 FlashPlayerInstaller.exe -install -iv 9
                0004 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/24.0 2
                0005 [I] 00000011 1
                0006 [I] 00000020 C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
                0007 [W] 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
                0008 [W] 00001015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe 5
                0009 [W] 00001045 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe 5
                0010 [W] 00001015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_16_0_0_305_ActiveX.exe 5
                0011 [W] 00001037 SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\\FlashUtil32_16_0_0_305_ActiveX.exe/ 2
                0012 [I] 00000013
                0013 [I] 00000015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_24_0_0_194_ActiveX.exe
                0014 [I] 00000016 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_24_0_0_194_ActiveX.dll
                0015 [I] 00000023 C:\WINDOWS\SysWOW64\Macromed\Flash\activex.vch
                0016 [I] 00000019 C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
                0017 [I] 00000021 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
                0018 [E] 00001031 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe:5
                =X====== M/24.0.0.194 2017-01-30+09-04-09.545 ========
                • 5. Re: Background Update Server - FlashPlayerUpdateService.exe deleted ?
                  jpfeif Adobe Employee
                  Hi Boris, to help us resolve this issue please perform the following troubleshooting steps and share the results with us:
                  1. Create a Process Monitor log file:
                  You can download Process Monitor from: https://technet.microsoft.com/en-us/sysinternals/processmonitor.aspx.
                  Run Process Monitor and remove any default filters. Then reproduce the issue, waiting until the FlashPlayerUpdaterService.exe file is deleted. Then send us the Process Monitor log file.
                  2. Install the old Flash Player using an EXE installer instead of an MSI installer, then try to reproduce the issue. You can find old Flash Player EXE installers at Archived Adobe Flash Player versions.
                  3. Disable any running antivirus programs, then try to reproduce the issue.
                  4. Launch a command prompt "As administrator" and run the commands below, then try to reproduce the issue.
                  net start PcaSvc
                  net start AeLookupSvc
                  John
