4 Replies Latest reply on Sep 29, 2016 11:34 AM by risingj
    Changes to Google Play GPS manifest requirements October 15th, 2016
    mattk91945366
      I received an email from Google today saying:
      Hello Google Play Developer,
      We're writing to let you know that the apps listed at the end of this email may be affected by an upcoming platform change.
      Action required: If your app requires GPS hardware to operate properly, you will need to explicitly add the "android.hardware.location.gps" uses-feature to your manifest.
      What’s changing
      We’re making a change on October 15th, 2016 that will affect apps targeting API version 21 (Android 5.0, Lollipop) or higher that use ACCESS_FINE_LOCATION but don't explicitly have the "android.hardware.location.gps" uses-feature. Going forward, these apps will be available to install on devices that don't have GPS hardware. In most cases this won't be an issue since Wi-Fi and Cell-ID based location provides high enough fidelity for the typical operation of these apps. However, any apps that require GPS hardware, such as GPS navigators, should explicitly add the "android.hardware.location.gps" uses-feature to their manifest.
      If your app requires GPS to function properly and you do not include android.hardware.location.gps in your manifest declaration, your users may have a poor app experience.
      Also, if you’re using the fused location provider and wish to receive the most accurate location samples from GPS (i.e. with PRIORITY_HIGH_ACCURACY), you must include the "android.hardware.location.gps" feature in your app’s manifest to ensure that Google Play only distributes your app to devices with GPS sensors.
      Currently, I'm using the <plugin name="cordova-plugin-geolocation" source="npm" /> for location.
      Do I need to change anything on my end or does that plugin take care of this situation?
