4 Replies Latest reply on Oct 5, 2016 8:39 AM by Loic.Aigon
    InDesign CC not showing up in Extensions Manager
    NIRC Level 1
      When I open Extension Manager CC (Windows 10), it comes up without any programs showing. This means I cannot install an expensive extension I just purchased.
      I ran Adobe ExtendScript Toolkit CC with "BridgeTalk.__diagnostics__;"
      Here are the results (where InDesign CC shows up as a "target":
      Targets: 14
        Connector = PCD
         Installed: 0
         Running: 0
          ame-6.0:
        Group = cs
        Path = C:\Program Files (x86)\Adobe\Adobe Media Encoder CS6\Adobe Media Encoder.exe
        Display Name = Adobe Media Encoder
        MsgAuthentication = ON
        MsgDigest = ON
        ESTK = ON
        Status = (not running)
        ExeName = Adobe Media Encoder.exe
          bridge-5.032:
        Group = cs
        Path = C:\Program Files (x86)\Adobe\Adobe Bridge CS6\Bridge.exe
        Display Name = Bridge CS6
        MsgDigest = ON
        ESTK = ON
        ExeName = Bridge.exe
          bridge-5.064:
        Group = cs
        Path = C:\Program Files\Adobe\Adobe Bridge CS6 (64 Bit)\Bridge.exe
        Display Name = Bridge CS6 (64 bit)
        MsgDigest = ON
        ESTK = ON
          bridge-6.364:
        Group = cs
        Path = C:\Program Files\Adobe\Adobe Bridge CC 2015\Bridge.exe
        Display Name = Bridge CC 2015 (64 bit)
        MsgDigest = ON
        ESTK = ON
          estoolkit-3.8:
        Group = cs
        Path = C:\Program Files (x86)\Adobe\Adobe Utilities - CS6\ExtendScript Toolkit CS6\ExtendScript Toolkit.exe
        Display Name = ExtendScript Toolkit CS6
        MsgDigest = ON
        ESTK = ON
        ExeName = ExtendScript Toolkit.exe
          estoolkit-4.0: PUMPING
        Group = cs
        Path = C:\Program Files (x86)\Adobe\Adobe ExtendScript Toolkit CC\ExtendScript Toolkit.exe
        Display Name = ExtendScript Toolkit CC
        MsgDigest = ON
        ESTK = ON
        Status = PUMPING
          Info:
        Group = cs
        Version = 2.0
        Build = ES 4.5.5
        Next serial number = 48
        Logging: = OFF
        Now = 13:29:05
        Message Version = 2.05
        Authentication = ON
        Digest = ON
          Thread: estoolkit-4.0#thread
        Avg. pump interval = 30ms
        Last pump = 260ms ago
          Ping: 7
          ECHO_REQUEST: ECHO_RESPONSE
        Timeout = undefined
        Handler = undefined
          STATUS: PUMPING
        Timeout = undefined
        Handler = undefined
          MAIN: MAIN
        Timeout = undefined
        Handler = installed
          LAUNCHED: LAUNCHED
        Timeout = undefined
        Handler = installed
          DIAGNOSTICS: DIAGNOSTICS
        Timeout = undefined
        Handler = installed
          INFO: INFO
        Timeout = undefined
        Handler = installed
          SETUPTIME: thread=0ms, left=69ms
        Timeout = undefined
        Handler = undefined
          exman-6.0:
        Group = cs
        Path = C:\Program Files (x86)\Adobe\Adobe Extension Manager CS6\Adobe Extension Manager CS6.exe
        Display Name = Adobe Extension Manager CS6
        MsgDigest = ON
        ESTK = OFF
        BundleID = com.adobe.exman
        ExeName = Adobe Extension Manager CS6.exe
          exman-7.0:
        Group = cs
        Path = C:\Program Files (x86)\Adobe\Adobe Extension Manager CC\Adobe Extension Manager CC.exe
        Display Name = Adobe Extension Manager CC
        MsgDigest = ON
        ESTK = OFF
        ExeName = Adobe Extension Manager CC.exe
        indesign-11.064:
        Path = C:\Program Files\Adobe\Adobe InDesign CC 2015\InDesign.exe
        Display Name = Adobe InDesign CC 2015
        MsgDigest = ON
        ESTK = ON
        ExeName = InDesign.exe
        indesign-8.0:
        Group = cs
        Path = C:\Program Files (x86)\Adobe\Adobe InDesign CS6\InDesign.exe
        Display Name = Adobe InDesign CS6
        MsgDigest = ON
        ESTK = ON
      Any ideas on how to fix this. I uninstalled and reinstalled Extensions Manager several times, rebooting each time, but to no avail.
        • 1. Re: InDesign CC not showing up in Extensions Manager
          Did you try to install it again? Start to install the Extension Manager again.
          If that does not work, uninstall everything, run Adobe's Creative Cloud Cleaner Tool (you get it on their download page), and install everything clean again. Save before all settings, actions in Photoshop, Swatches, etc.
          • 2. Re: InDesign CC not showing up in Extensions Manager
            NIRC Level 1
            Thanks for the reply. I recognize your name as someone who has helped me before, some years back.
            I uninstalled and reinstalled Extensions Manager three times, rebooting at each stage. I am a little anxious about uninstalling everything with Creative Cloud. Does it ONLY uninstall the CC programs or does it uninstall the CS6 programs as well? I really want to avoid the latter.
              Also, once I have uninstalled, may I assume that the Creative Cloud will still recognize me as registered and let me reinstall.
              I should mention something odd: the exact same thing happens on a second computer where InDesign CC is installed. I mean exact same thing. This leads me to doubt that the problem was on my end...
              I will wait for your thoughts before taking the plunge.
            • 3. Re: InDesign CC not showing up in Extensions Manager
              NIRC Level 1
              I followed the instructions for Removing Creative Cloud Cleaner tool (Use the Creative Cloud Cleaner Tool to solve installation problems ) and then reinstalled InDesign CC and Extensions Manager CC. Then I opened the Extensions Manager (as administrator) and found that there is still nothing showing. I also noticed that all my scripts and other preferences under Roaming...\Version 11.0\ en_US as well as under the InDesign Plugins subdirectory were all there--even though I had instructed the Cleaner NOT to save the preferences.
              • 4. Re: InDesign CC not showing up in Extensions Manager
                Loic.Aigon Adobe Community Professional
                ExtensioManager has been discarded by Adobe since CC(2014 I think) so now you need to distribute your extensions through Adobe Addons. Otherwise you can decide to distribute extension yourself but then client will have to either use the command line tool or install them manually.
                FWIW
                Loic
