1 Reply Latest reply on Sep 20, 2016 3:22 PM by Chris W. Griffith
    Error 404 while posting data to local file
    kasjuszek Level 1
      Hello
      In project's www folder I have app.xml file with some data deserialized during application start. I use jQuery GET to read settings like in example:
      $.get("app.xml", function(data){
          $("#mac").val($(data).find('macAddress')[0].innerHTML);
      The issue begins with trying to serialize new data back to the file. The simplest way is to use POST method (I tried also XMLHttpRequest and FileWriter):
      $.post("app.xml", function(data){
              $(this).find('files').append(data);
      When i run this function, console responds with some kind of access problem (while get works fine):
      POST http://192.168.1.11:3000/app.xml 404 (Not Found) send @ jquery-2.1.4.js:8630ajax
      I've read about similar problems, the solution was always cordova whitelist plugin. In my case it did not work, neither in browser, nor in android app.
      config.xml:
      <plugin name="cordova-plugin-whitelist" source="npm" spec="~1.2.1"/>
      <access origin="*"/>
        <allow-intent href="*" />
        <allow-navigation href="*" />
        <platform name="android">
          <allow-intent href="*"/>
        </platform>
      It looks to me that I miss some data write privileges, but it's weird to me, that it doesn't work even in browser. How should I properly store program settings?
