8 Replies Latest reply on Sep 22, 2016 8:11 AM by Peter Kahrel
    finding all docs with a specific link filePath
    jakec88782761 Level 2
      Hello,
      I'm trying to find out the name of all documents with a specific link filePath.
      Before I run this script I need to know that nothing bad is going to happen, so please can someone give me some advice?
      var myFolder = Folder ("A:\Work in progress/Jake/Indd Files/");
      var myDocs=[];
      var myFiles = myFolder.getFiles("*");
      for (i=0;i<myFiles.length;i++){
          $.writeln(myFiles[i].displayName);
         var doc =  myFiles[i].open();
         var docLinks = doc.links;
         for (j=0;j<docLinks.length;j++){
             if (docLinks[i].filePath="A:\Work in progress\Jake\Image Links\Aqualimb 100kg\Aqua Limb.eps"){
                 myDocs.push(doc.name)
             doc.close();
        • 1. Re: finding all docs with a specific link filePath
          Peter Kahrel Adobe Community Professional & MVP
          is not going to work, because \W will be interpreted as a control character. Use either of these two:
          Folder ("A:\\Work in progress\\Jake\\Indd Files\\");
          Folder ("/A/Work in progress/Jake/Indd Files/");
          might not work either. Use myFolder.getFiles("*.*");
          And links have a name, which is the graphic's name, so you could do something like this:
          if (docLinks[i].name === 'Aqua Limb.eps')
          And mind your =s: docLinks[i].filePath = "..." tries to set the file path, which is not possible anyway, so your script would break on that (I guess).
          Peter
          • 2. Re: finding all docs with a specific link filePath
            It finds the folder fine as it is, as the console logs them all.
            I changed the docLinks to var docLinks = doc.links.everyItem(); as I realise you have to loop through a collection/array.
            I get an error on the bolded line saying that it's undefined.
            var myDocs=[];
                   doc.close();
            • 3. Re: finding all docs with a specific link filePath
              Use either of these, not what you had:
              var docLinks = doc.links.everyItem().getElements();
              or
              And if (docLinks[i].filePath="A:\Wor. . . is wrong: use ===, not =
              • 4. Re: finding all docs with a specific link filePath
                tpk1982 Level 4
                try this
                var myDocs=[];
                var myFiles = myFolder.getFiles("*.*");
                    app.open(myFiles[i]);
                    var doc=app.activeDocument;
                    var docLinks = doc.allGraphics;
                    if (docLinks[i].itemLink.filePath=="A:\Work in progress\Jake\Image Links\Aqualimb 100kg\Aqua Limb.eps"){
                      app.activeDocument.close();
                alert(myDocs.join("\r"))
                • 5. Re: finding all docs with a specific link filePath
                  Thanks for your reply.
                  I wasn't accessing the open document correctly.
                  This doesn't throw any errors but the alert is always empty and nothing appears to open during the loop.
                  var myDocs=[];
                     var docLinks =app.activeDocument.links.everyItem().getElements();
                     var activeDoc = app.activeDocument;
                         if (docLinks[i].filePath==="A:\Work in progress\Jake\Image Links\Aqualimb 100kg\Aqua Limb.eps"){
                             myDocs.push(activeDoc.name, "\r")
                              doc.close();
                  alert(myDocs);
                  • 6. Re: finding all docs with a specific link filePath
                    Hello, this looks way better than mine.
                    I ran it and it works, but there is a problem with this loop:
                    It gets to a certain document and then says null is not an object.
                    • 7. Re: finding all docs with a specific link filePath
                      This works up until a certain point but then return object is not valid for this line :
                      if (docLinks[i].name==="Aqua Limb.eps")
                      It runs fine for like 10 documents then throws this error on the same document each time.
                      var myDocs=[];
                         if (docLinks[i].name==="Aqua Limb.eps"){
                             $.writeln(myDocs);
                      • 8. Re: finding all docs with a specific link filePath
                        i keeps track of the documents, not the links. You need a separate counter for the links, somethin like
                        for (j = 0; j < docLinks.length; j++) {
                          if (docLinks[j].name==="Aqua Limb.eps") {
                        Peter
