4 Replies Latest reply on Sep 22, 2016 11:56 PM by Vishal Sharma
    Not able to create build for windows in PhoneGap.
    Vishal Sharma
      Hey guys,
      I got windows computer.
      Then i did try follow below URL to install PhoneGap CLI into Windows.
      Step 1: Install PhoneGap | PhoneGap Docs
      Then i did try below comand :
      phonegap local build windows
      But i got same below:
      Error is :
      Error: No valid MSBuild was detected for the selected target.
      After get this error i did install Microsoft Build from below :
      Download Microsoft Build Tools 2015 from Official Microsoft Download Center
      All things are installed properly , Then again i tried to create local build via :
      Now, I got another error. Below is error log from my command prompt:
      [warning] The command `phonegap local <command>` has been DEPRECATED.
      [warning] The command has been delegated to `phonegap <command>`.
      [warning] The command `phonegap local <command>` will soon be removed.
      [phonegap] executing 'cordova build windows ' ...
      The following navigation rule had an invalid URI scheme and is ignored: "*".
      Building project: C:\Users\DELL\Desktop\MYPROJECTNAME\platforms\windows\CordovaApp.Windows.jsproj
      Configuration : debug
      Platform      : anycpu
      C:\Users\DELL\Desktop\UponorMore\platforms\windows\CordovaApp.Windows.jsproj(52,5): error MSB4019: The imported project "C:\Program Files (x86)\MSBuild\Microsoft\VisualStudio\v14.0\Microsoft.VisualStudio..Default.props" was not found. Confirm that the path in the <Import> declaration is correct, and that the file exists on disk.
      Error: C:\Program Files (x86)\MSBuild\14.0\bin\msbuild.exe: Command failed with exit code 1
      Is any body have any idea regarding it?
      with this pic.
