4 Replies Latest reply on Sep 22, 2016 5:57 AM by discrhythmia
    Keep getting TypeError: RngTable[UpperWt] is undefined
    discrhythmia
      I need help trying to solve / fix the above error.
      I understand why/where the error is occurring, I just can't figure out how to properly resolve it.
      When I enter a value between 10000 and 18000 in the Weight field ( AW variable ), this works, however, when I enter 18001, I get the above error.- Suggestions?
      Thanks in advance!
      var AW = this.getField("Weight").value;
      var b = Math.ceil(AW / 1000) * 1000;
      var c = Math.floor(AW/ 1000) * 1000;
      var d = 10000;
      var e = 18300;
      var UpperWt = b;
      if (b > e) {
      UpperWt.value = e;
      } else {
      UpperWt.value = b;
      var LowerWt = c;
      if (c < d) {
      LowerWt.value = d;
      } else {
      LowerWt.value = c;
      var t = this.getField("Temperature").value;
      var RngTable = new Array();
      RngTable[18300] = ["4686","4857","5029","5201","5942","7370"];
      RngTable[18000] = ["4530","4695","4860","5025","5732","7088"];
      RngTable[17000] = ["4010","4152","4295","4437","5031","6149"];
      RngTable[16000] = ["3550","3675","3800","3925","4412","5285"];
      RngTable[15000] = ["3127","3229","3330","3431","3857","4663"];
      RngTable[14000] = ["2744","2841","2938","3035","3412","4090"];
      RngTable[13000] = ["2382","2461","2540","2619","2925","3475"];
      RngTable[12000] = ["2242","2314","2385","2456","2727","3203"];
      RngTable[11000] = ["2160","2227","2295","2362","2592","2958"];
      RngTable[10000] = ["2085","2152","2220","2287","2493","2787"];
      var nWT = this.getField("Weight").value;
      var nTEMP = 5;
      console.println("Hello World1");
      var f = Math.round(((((RngTable[UpperWt][nTEMP]) - (RngTable[UpperWt][nTEMP-1])) / 11) * (t - 27)) + (1 * RngTable[UpperWt][nTEMP-1]));
      console.println("Hello World2");
      var g = Math.round(((((RngTable[LowerWt][nTEMP]) - (RngTable[LowerWt][nTEMP-1])) / 11) * (t - 27)) + (1 * RngTable[LowerWt][nTEMP-1]));
      console.println("Hello World3");
      if (AW >= LowerWt && AW <= UpperWt) {
      this.getField("UWt_Dist").value = Math.round(((((RngTable[UpperWt][nTEMP]) - (RngTable[UpperWt][nTEMP-1])) / 11) * (t - 27)) + (1 * RngTable[UpperWt][nTEMP-1]));
      console.println("Hello World4");
      this.getField("LWt_Dist").value = Math.round(((((RngTable[LowerWt][nTEMP]) - (RngTable[LowerWt][nTEMP-1])) / 11) * (t - 27)) + (1 * RngTable[LowerWt][nTEMP-1]));
      console.println("Hello World5");
      this.getField("CWt_Dist").value = ((((f - g) / (UpperWt-LowerWt)) * (AW - LowerWt)) + (g));
        • 1. Re: Keep getting TypeError: RngTable[UpperWt] is undefined
          George_Johnson MVP & Adobe Community Professional
          I haven't looked through the entire script, but this bit of code:
          var UpperWt = b;
          if (b > e) {
          UpperWt.value = e;
          } else {
          UpperWt.value = b;
          needs to be changed to this:
          var UpperWt = b;
          if (b > e) {
          UpperWt = e;
          } else {
          UpperWt = b;
          Do the same type of correction to the next block as well.
          • 2. Re: Keep getting TypeError: RngTable[UpperWt] is undefined
            And it can be simplified to:
            var UpperWt = b;
            if (b > e) {
                UpperWt = e;
            • 3. Re: Keep getting TypeError: RngTable[UpperWt] is undefined
              Once you've made those changes please repost the script AND the complete console log.
              • 4. Re: Keep getting TypeError: RngTable[UpperWt] is undefined
                discrhythmia Level 1
                That worked like a charm!
                Thanks!
                var d = 10000;
                var e = 18300;
                var UpperWt = b;
                if (b > e) {
                    UpperWt = e;
                var LowerWt = c;
                if (c < d) {
                LowerWt = d;
                var nTEMP = 5;
                }Hello World1
                Hello World2
                Hello World3
                Hello World4
                Hello World5
