1 Reply Latest reply on Nov 25, 2016 5:09 AM by Rodolpho Nascimento
    Problem in dynamically added Datagrid in Flex Project
    lokeshg17814194
      Hi Everyone,
      I'm new to flex Builder. I trying to do a small project with Flex Builder in Asp.Net. I'm facing a small problem as described below.
      I wanted to generate dynamic multiple Datagrids inside a panel using ModelLocator class. My code is working good if i run the click the button twice, please guide me to fix the problem.
      <mx:Application
        xmlns:mx="http://www.adobe.com/2006/mxml"
        xmlns:business="com.flexWebMsSqlExplorer.webMsSql.business.*"
          xmlns:control="com.flexWebMsSqlExplorer.webMsSql.control.*"
          xmlns:components="com.flexWebMsSqlExplorer.webMsSql.components.*"
          layout="absolute"
          creationComplete="init();"
          keyUp="handleShortCuts(event);">
        <mx:Script>
        <![CDATA[
        import mx.controls.DataGrid;
        import mx.controls.Alert;
        import com.flexWebMsSqlExplorer.webMsSql.view.AboutWindow;
        import com.flexWebMsSqlExplorer.webMsSql.events.InitEvent;
        import com.flexWebMsSqlExplorer.webMsSql.view.LoginWindow;
        import com.flexWebMsSqlExplorer.webMsSql.view.OpenTableWindow;
        import mx.rpc.soap.mxml.WebService;
        import mx.managers.PopUpManager;
        import com.flexWebMsSqlExplorer.webMsSql.events.MetaDataEvent;
        import com.flexWebMsSqlExplorer.webMsSql.events.ExecuteSQLEvent;
        import com.flexWebMsSqlExplorer.webMsSql.model.ModelLocator;
        import com.flexWebMsSqlExplorer.webMsSql.vo.ConnectionVO;
        import com.adobe.cairngorm.business.ServiceLocator;
        import com.adobe.cairngorm.control.CairngormEventDispatcher;
        import com.flexWebMsSqlExplorer.webMsSql.components.DebugWindow;
        import com.flexWebMsSqlExplorer.webMsSql.components.QueryWindow;
        public var debug_win:DebugWindow;
        private var exectimer:Timer;
        [Bindable]
                  private var model:ModelLocator = ModelLocator.getInstance();
        public function init():void{
        //Popup Debug
        //debug_win = PopUpManager.createPopUp(this, DebugWindow, false) as DebugWindow;
        //DebugWindow.log("main.mxml:init()");
        //Register Some Things with the model
        model.aryQueryWindows.push(QueryWindow1);
        model.showplanwindow = showplanwin;
      // model.querydatagrid = querydatagrid;
      // model.querydatagrid1 = querydatagrid1;
        //Locate and load the wsdl page
                  var urlpattern:RegExp = /webMsSql.swf/i;
                  var wsdl:String = "";
                  try{
                  // If there is a flash variables from the html page, lets use, otherwise default it to the current directory
                  if(Application.application.parameters.webservice == undefined || Application.application.parameters.webservice == '' ){
                  wsdl = this.url.replace(urlpattern, "flexWebMsSqlExplorer.asmx?WSDL");
                  } else {
                  wsdl = Application.application.parameters.webservice;
                  //DebugWindow.log("Using WSDL location - " + wsdl);
                  var s:WebService = ServiceLocator.getInstance().getService("sqlWebService") as WebService;
        s.wsdl = wsdl;
        s.loadWSDL();
                  } catch (e:Error){
                  mx.controls.Alert.show("Error Loading WSDL", "WSDL Error");
        //Popup the login box
        var loginForm:LoginWindow = LoginWindow(PopUpManager.createPopUp(this, LoginWindow, false));
                   loginForm.setStyle("borderAlpha", 0.8);
                  loginForm.showCloseButton = true;
        public function repeator():void{
        for (var icon:int = vboxresults.numChildren-1; icon >= 0; icon--) {
          vboxresults.removeChildAt (icon);
                   for(var xcon:int=0;xcon<model.querydatagrid.length;xcon++)
        vboxresults.addChild(model.querydatagrid[xcon]);
        private function openTable(table:String):void{
        var opentablewindow:OpenTableWindow = OpenTableWindow(PopUpManager.createPopUp(this, OpenTableWindow, true));
                   opentablewindow.setStyle("borderAlpha", 0.8);
                  opentablewindow.showCloseButton = true;
                  opentablewindow.setTablename(table);
                  private function showLogin():void{
                  DebugWindow.log("main.mxml:showLogin()");
                  var loginForm:LoginWindow = LoginWindow(PopUpManager.createPopUp(this, LoginWindow, true));
                  private function loadMetaData():void{
                  DebugWindow.log("main.xml:loadMetaData() - Connection " + model.connectionVO.getConnectionString());
                  var metaevent:MetaDataEvent = new MetaDataEvent();
                  CairngormEventDispatcher.getInstance().dispatchEvent(metaevent);
                  private function addTab():void{
                  DebugWindow.log("main.mxml:addTab()");
                  var qw:QueryWindow = new QueryWindow();
                  qw.setLabel("Query " + (model.aryQueryWindows.length + 1).toString());
                  model.aryQueryWindows.push(qw);
                  tabnavigator.addChild(qw);
                  tabnavigator.selectedIndex = tabnavigator.numChildren - 1;
                  private function closeTab():void{
                  DebugWindow.log("main.mxml:closeTab()");
                  if(tabnavigator.numChildren > 1){
                          for(var c:int = tabnavigator.selectedIndex; c < model.aryQueryWindows.length; c++){
                              model.aryQueryWindows[c] = model.aryQueryWindows[c + 1];
                          model.aryQueryWindows.pop();
                          tabnavigator.removeChildAt(tabnavigator.selectedIndex);
                  private function submitQuery():void{
                  DebugWindow.log("main.mxml:submitQuery()");
                  DebugWindow.log("main.mxml:Query text - " + model.aryQueryWindows[tabnavigator.selectedIndex].getQueryText());
                  var sqt:String = "normal";
                  if(spflag.selected)
                       sqt = "spnormal";
                  var sqlevent:ExecuteSQLEvent = new ExecuteSQLEvent(model.aryQueryWindows[tabnavigator.selectedIndex].getQueryText(), sqt);
                  CairngormEventDispatcher.getInstance().dispatchEvent(sqlevent);
                  tabresults.selectedIndex = 0;
                  private function submitParseQuery():void{
                  DebugWindow.log("main.mxml:submitParseQuery()");
                  var sqlevent:ExecuteSQLEvent = new ExecuteSQLEvent(model.aryQueryWindows[tabnavigator.selectedIndex].getQueryText(), "parse");
                  private function submitShowPlanQuery():void{
                  DebugWindow.log("main.mxml:submitShowPlanQuery()");
                  var sqlevent:ExecuteSQLEvent = new ExecuteSQLEvent(model.aryQueryWindows[tabnavigator.selectedIndex].getQueryText(), "showplan");
                  tabresults.selectedIndex = 2;
                  private function clearQuery():void{
                  model.aryQueryWindows[tabnavigator.selectedIndex].clearQuery();
                  private function showAboutWindow():void{
                  var aboutWindow:AboutWindow = AboutWindow(PopUpManager.createPopUp(this, AboutWindow, true));
                   aboutWindow.setStyle("borderAlpha", 0.8);
                  aboutWindow.showCloseButton = true;
                  private function handleShortCuts(e:KeyboardEvent):void{
                      if(e.keyCode == 116)
                          submitQuery();
                      else if (e.keyCode == 117)
                          clearQuery();
                      else if (e.ctrlKey && e.keyCode == 84)
                          addTab();
                      else if (e.ctrlKey && e.keyCode == 82)
                          loadMetaData();
        else if(e.keyCode == 9){
                  var spacer:String = "\t";
                  var cutter:int = 0;
                  var tempquery:TextArea = model.aryQueryWindows[tabnavigator.selectedIndex].querytext;
                  if(tempquery.text.charCodeAt(tempquery.selectionBeginIndex - 1) == 13 || tempquery.selectionBeginIndex == 0)
                  spacer = " \t";
                  if (! e.shiftKey){
                  tempquery.text = tempquery.text.substring(0, tempquery.selectionBeginIndex) + spacer + tempquery.text.substring(tempquery.selectionBeginIndex, tempquery.length);
        tempquery.setSelection(tempquery.selectionBeginIndex + spacer.length, tempquery.selectionBeginIndex + spacer.length);
                  } else {
                  if (tempquery.selectionBeginIndex > 0 && tempquery.text.charCodeAt(tempquery.selectionBeginIndex - 1) == 9){
                    tempquery.text = tempquery.text.substring(0, tempquery.selectionBeginIndex - 1) + tempquery.text.substring(tempquery.selectionBeginIndex, tempquery.length);
        tempquery.setSelection(tempquery.selectionBeginIndex - 1, tempquery.selectionBeginIndex - 1);
        tempquery.setFocus();
        model.aryQueryWindows[tabnavigator.selectedIndex].parseQuery(new KeyboardEvent(""));
        else if(e.ctrlKey && e.keyCode == 67){
        copy();
        } else if(e.ctrlKey && e.keyCode == 88){
        cut();
                  private function copy():void{//67
                  System.setClipboard(tempquery.text.substring(tempquery.selectionBeginIndex, tempquery.selectionEndIndex));
                  private function cut():void{ //88
                  tempquery.text = tempquery.text.substring(0, tempquery.selectionBeginIndex) + tempquery.text.substring(tempquery.selectionEndIndex, tempquery.length);
        </mx:Script>
        <!-- the ServiceLocator where we specify the remote services -->
          <business:Services id="loginServices" />
          <!-- the FrontController, containing Commands specific to this appliation -->
          <control:Controller id="controller" />
        <mx:Style>
              Application{
                  paddingLeft: 10px;
                  paddingRight: 10px;
                  paddingTop: 10px;
                  paddingBottom: 10px;
                  backgroundGradientColors: #AEC5E7, #5E8ED7;
              HDividedBox{
              paddingLeft: 10px;
                  paddingRight: 10px;
                  paddingTop: 10px;
              TextArea {
              fontFamily: Verdana;
              fontSize: 12pt;
          </mx:Style>
        <mx:HDividedBox width="100%" height="100%" horizontalGap="5" liveDragging="true">
        <mx:VBox height="100%" width="30%" >
        <mx:HBox width="100%">
        <mx:Button click="loadMetaData();" icon="@Embed(source='icons/cog.png')" toolTip="(CTRL-R) Refresh Object Browser" label="Refresh"/>
        <mx:Button click="showLogin();" label="Reconnect" icon="@Embed(source='icons/connect.png')"/>
        </mx:HBox>
        <components:ObjectBrowser tabnav="{tabnavigator}" dataProvider="{model.metadata}"/>
        </mx:VBox>
          <mx:VDividedBox width="100%" height="100%" verticalGap="5" liveDragging="true">
        <mx:Box width="100%" height="50%">
        <mx:Button click="submitParseQuery();" icon="@Embed(source='icons/parse.png')" label="Parse Query" toolTip="Parse Query"/>
            <mx:Button click="submitQuery();" toolTip="(F5) Submit Query" label="Submit Query" icon="@Embed(source='icons/exec.gif')" id="btnQuery" width="108"/>
            <mx:Button click="clearQuery();" icon="@Embed(source='icons/clear.png')" toolTip="(F6) Clear Query" label="Clear Query"/>
            <mx:Button click="submitShowPlanQuery();" icon="@Embed(source='icons/exec_plan.png')" label="Show Execution Plan" toolTip="Show Execution Plan"/>
            <mx:CheckBox label="Include Execution Plan" id="spflag"/>
            <mx:Spacer width="100%"/>
            <mx:Button click="showAboutWindow();" icon="@Embed(source='icons/information.png')" label="About" toolTip="About"/>
        </mx:HBox>
        <mx:Button click="addTab();" icon="@Embed(source='icons/add_tab.png')" toolTip="(CTRL-T) Add Tab" id="addtab" label="Add Tab" width="79"/>
        This might come out in a future release. The functionality is there, just no paste ability yet.
        <mx:Button icon="@Embed(source='icons/cut.png')" toolTip="(CTRL-X) Cut" label="Cut" click="cut();"/>
        <mx:Button icon="@Embed(source='icons/copy.png')" toolTip="(CTRL-C) Copy" label="Copy" click="copy();"/>
          <mx:Button click="closeTab();" icon="@Embed(source='icons/close_tab.png')" label="Close Tab" id="closetab"/>
        </mx:HBox>
           <mx:TabNavigator id="tabnavigator" width="100%" height="100%" alpha=".8">
               <components:QueryWindow id="QueryWindow1" label="Query 1"/>
           </mx:TabNavigator>
           </mx:Box>
            <mx:TabNavigator id="tabresults" width="100%" height="90%" alpha=".8">
               <mx:Canvas  width="100%" height="100%" label="Result" icon="@Embed(source='icons/result.png')">
         <mx:HBox verticalAlign="middle" horizontalGap="15" width="100%">
          <mx:VBox id="vboxresults" horizontalAlign="left" verticalGap="15" width="100%">
                         Here I'm adding Dynamic Grids using the modal locator class and repeator() action script funtion
                   </mx:VBox>
                 </mx:HBox>
               </mx:Canvas>
               <mx:Canvas id="messages" label="Messages" icon="@Embed(source='icons/messages.png')">
                   <mx:TextArea text="{model.querymessages}" width="100%" height="100%" wordWrap="false" horizontalScrollPolicy="auto" editable="false"/>
               </mx:Canvas>
               <components:ExecutionPlanWindow width="100%" height="100%" id="showplanwin" label="Execution Plan" icon="@Embed(source='icons/exec_plan.png')"/>
               <mx:Canvas id="history" label="History" icon="@Embed(source='icons/history.png')">
                   <mx:TextArea htmlText="{model.queryHistoryVO.history}" width="100%" height="100%" wordWrap="false" horizontalScrollPolicy="auto" editable="false" id="txtHistory"/>
               </mx:Canvas>
           </mx:TabNavigator>
            <mx:Label fontWeight="bold" text="Elapsed Execution Time: {model.exectimer.time} sec(s)"/>
            <mx:Label fontWeight="bold" text="{model.connectionText}"/>
            </mx:HBox>
           </mx:Box>
        </mx:VDividedBox>
          </mx:HDividedBox>
      </mx:Application>
