2 Replies Latest reply on Sep 22, 2016 8:57 AM by ryanskihead
    Error when trying to upload a file to phonegap build with codio
    kmcu
      I will copy my previous post from the codio forum.
      "I am trying to use ionic with codio since it makes it easy to install an app through phonegap build.
      When I try uploading the app to phonegap build I receive the "java.net. SocketTimeoutException: Read timed out"error.
      If it helps I created my project using the node js stack in order to install ionic through the command line. The only info I was able to find about my problem is from this site http://stackoverflow.com/questions/29408363/ionic-framework-phonegap-build-workflow
      Any ideas?"
      I was told that the java.net. SocketTimeoutException: Read timed out error means im having trouble connecting to the server, and should ask the question here instead.
