4 Replies Latest reply on Jan 31, 2017 9:02 AM by cjbrody
    cordova-sqlite-storage error - occurs even when all plugins are removed
      On build.phonegap the iOS and Android builds fail with the following error message:
      Error - Plugin error (you probably need to remove plugin files from your app): Fetching plugin "cordova-sqlite-storage@~1.4.7" via npm Installing "cordova-sqlite-storage" at "1.4.7" for ios Error during processing of action! Attempting to revert... Failed to install 'cordova-sqlite-storage':CordovaError: Uh oh!
      In config we have:
      <plugin name="cordova-sqlite-storage" source="npm" spec="~0.8.5"/>
      The config.xml hasn't been modified in weeks, and the build worked fine for weeks, then two days ago it started failing suddenly.
      We get the "cordova-sqlite-storage@~1.4.7" error message even if we remove the reference to cordova-sqlite-storage plugin from config.xml,
      the message still occurs even when we remove all of the plugins from the config.
      On September 21/22 the status.build.phonegap.com was showing issues with the build server, and that seems to be fixed now, however the 'cordova-sqlite-storage' plugin error is still occuring even if it's not referenced in config.xml
