26 Replies Latest reply on Jul 18, 2017 8:31 AM by CN13579
    Numbered Lists with Dynamic Content Filtering
    CN13579 Level 1
      I couldn't find this information anywhere, though I would imagine I'm probably not the first person to encounter this issue...
      I have some topics where the steps in procedures are presented with numbered lists. I'm using Conditional Build Tags on some of the numbered steps to filter them out when specific filters are applied in the Responsive HTML5 output. When I look at a topic in the preview mode and apply filters, the list numbers automatically renumber to avoid skipping numbers. However, when I generate the output and then apply the filter, the rows disappear as expected, but the numbered lists skip the filtered numbers.
      For example:
      This filters as shown in the preview:
      But in the generated output, the numbering is way off:
      Is there any way to make this number correctly?
        • 1. Re: Numbered Lists with Dynamic Content Filtering
          Hi there
          Have you looked to ensure you haven't applied a specific start number to some of the stuff? I tested my own RoboHelp 2015 Release and the numbers filter out and maintain the numbering just fine. For example, if I have a list like this:
          1. List item one
          2. List item two
          3. List item three
          And the filtering removes list item two, my list looks like this:
          1. List item one
          2. List item three
          For the items that aren't following the numbering, I'd look at the list to ensure it doesn't resemble this:
          Cheers... Rick
          • 2. Re: Numbered Lists with Dynamic Content Filtering
            CN13579 Level 1
            Thanks for the reply. Did you try generating your list in Responsive HTML5 format? It works fine for me when I use the Robohelp preview feature, but when I actually generate the Responsive HTML5 output, it does not work. I have not specified any special numbering or restarts to the list.
            The list numbers seem to be hard coded in the html, so I'm guessing this is not something that it can do at run time?
            • 3. Re: Numbered Lists with Dynamic Content Filtering
              Jeff_Coatsworth Adobe Community Professional & MVP
              Can you show us an example of how the list numbering is appearing in the HTML output? I'm pretty sure you shouldn't be seeing the actual numbers if your list is defined correctly...
              • 4. Re: Numbered Lists with Dynamic Content Filtering
                CN13579 Level 1
                Sure. Here it is in the generated output:
                And here it is when viewing in Robohelp's preview (before generating):
                • 5. Re: Numbered Lists with Dynamic Content Filtering
                  Sorry, I meant, "let's see the source HTML code" in your topic and in the output.
                  • 6. Re: Numbered Lists with Dynamic Content Filtering
                    Well, considering the niggling little fact that the only output format that offers filtering at this point is Responsive HTML 5.
                    From what I've seen with my own testing, the numbers are certainly not hard coded as you are thinking.
                    Here, I recorded a small video to demonstrate.
                    Click here to view
                    Cheers... Rick
                    • 7. Re: Numbered Lists with Dynamic Content Filtering
                      CN13579 Level 1
                      Thanks for taking the time to demonstrate that. I do not believe there are any restarts in my code. I don't see any.  I'll paste code excerpts below as requested above. This is the Bullets and Numbering screen for step 9:
                      Perhaps it is relevant that I am using a Multilevel List style for these steps? I have the list style configured as shown:
                      Additionally, this section appears in two chapters so I have it in a snippet, though I tried it outside of a snippet and found the same issue. For reference, here's what the tagging looks like:
                      It does work fine in the preview mode. Could an Output setting be causing this?
                      Thanks for the help guys.
                      Here's an excerpt from the section shown in my last post. This is the HTML source in Robohelp:
                      When the Select Features window displays, click
                      the <b style="bidi-font-weight: normal; color: #800000;">Select All</b>
                      Tool, and click <b style="bidi-font-weight: normal; color: #800000;">Next</b>.</p><?rh-list_end ?>
                      <p class="List_Number_Image"><span style="no-proof: yes;"><img src="image27.jpg"
                        alt="" style="border: none;" border="0" /></span></p>
                      <?rh-list_start level="1" class="ML_List" style="list-style: rh-list; list-style: rh-list;" ?><p
                        class="List_Number">Continue with the SQL Server Service Pack installation.<span
                        style="spacerun: yes;">&#160;</span>&#160;This can take some time.</p><?rh-list_end ?>
                        class="List_Number">When the SQL Server Service Pack installation
                      is complete, shut down and restart the Server.</p><?rh-list_end ?>
                      <p class="List_Number_Image"><img src="image28.jpg" alt="" style="border: none;"
                                border="0" /></p>
                      <?rh-cbt_start condition="SQL_All_Versions" ?><?rh-list_start level="1"
                        class="List_Number">When you want to install Service Pack 2 (Service
                      Pack 2 is supported but not required for SQL Server 2008 R2 x64), <b style="bidi-font-weight: normal;">repeat
                      steps</b> <b style="bidi-font-weight: normal;">1</b> <b style="bidi-font-weight: normal;">through</b>
                      <b style="bidi-font-weight: normal;">4</b> to install Service Pack 2.<span
                        style="spacerun: yes;">&#160;</span>&#160;Otherwise, <b style="bidi-font-weight: normal;">skip
                      to step</b> <b style="bidi-font-weight: normal;">7</b>.</p><?rh-list_end ?><?rh-cbt_end ?>
                        class="List_Number">Install Service Pack 2 (Service Pack 2 is required
                      for SQL Server 2012 x64), <span><b style="bidi-font-weight: normal;">repeat
                      steps</b></span> <span><b style="bidi-font-weight: normal;">1</b></span>
                      <span><b style="bidi-font-weight: normal;">through</b></span> <span><b
                        style="bidi-font-weight: normal;">4</b></span> to install Service
                      Pack 2.<span style="spacerun: yes;">&#160;</span></p><?rh-list_end ?><?rh-cbt_end ?>
                        class="List_Number"><span>When you want to install Service Pack 3
                      (Service Pack 3 is supported, but not required for SQL Server 2008 R2
                      x64), <b style="bidi-font-weight: normal;">repeat steps</b> <b style="bidi-font-weight: normal;">1</b>
                      <b style="bidi-font-weight: normal;">through</b> <b style="bidi-font-weight: normal;">4</b>
                      to install Service Pack 3.</span><span style="spacerun: yes;">&#160;</span><span>&#160;Otherwise,
                      <b style="bidi-font-weight: normal;">skip to step</b> <b style="bidi-font-weight: normal;">7</b>.</span></p><?rh-list_end ?><?rh-cbt_end ?>
                      <?rh-cbt_start condition="SQL_2008" ?><?rh-list_start level="1" class="ML_List"
                      <?rh-cbt_start condition="SQL_2012" ?><?rh-list_start level="1" class="ML_List"
                      for SQL Server 2012 x64), <?rh-cbt_start condition="SQL_2012" ?><b style="bidi-font-weight: normal;">repeat
                      steps</b><?rh-cbt_end ?> <?rh-cbt_start condition="SQL_2012" ?><b style="bidi-font-weight: normal;">1</b><?rh-cbt_end ?>
                      <?rh-cbt_start condition="SQL_2012" ?><b style="bidi-font-weight: normal;">through</b><?rh-cbt_end ?>
                      <?rh-cbt_start condition="SQL_2012" ?><b style="bidi-font-weight: normal;">4</b><?rh-cbt_end ?>
                      to install Service Pack 2.<?rh-cbt_start condition="SQL_2012" ?><span
                        style="spacerun: yes;">&#160;</span><?rh-cbt_end ?></p><?rh-list_end ?><?rh-cbt_end ?>
                        class="List_Number">When you want to install Service Pack 3 (Service
                      Pack 3 is supported, but not required for SQL Server 2008 R2 x64), <?rh-cbt_start condition="SQL_2008" ?><b
                        style="bidi-font-weight: normal;">repeat steps</b><?rh-cbt_end ?>
                      <?rh-cbt_start condition="SQL_2008" ?><b style="bidi-font-weight: normal;">1</b><?rh-cbt_end ?>
                      <?rh-cbt_start condition="SQL_2008" ?><b style="bidi-font-weight: normal;">through</b><?rh-cbt_end ?>
                      <?rh-cbt_start condition="SQL_2008" ?><b style="bidi-font-weight: normal;">4</b><?rh-cbt_end ?>
                      to install Service Pack 3.<?rh-cbt_start condition="SQL_2008" ?><span
                        style="spacerun: yes;">&#160;</span><?rh-cbt_end ?>&#160;Otherwise,
                      <?rh-cbt_start condition="SQL_2008" ?><b style="bidi-font-weight: normal;">skip
                      to step</b><?rh-cbt_end ?> <?rh-cbt_start condition="SQL_2008" ?><b style="bidi-font-weight: normal;">7</b><?rh-cbt_end ?>.</p><?rh-list_end ?><?rh-cbt_end ?>
                        class="List_Number"><span style="bookmark: _Ref382406796;">Access
                      Windows Server Computer Management</span> <span style="bookmark: _Ref392685365;">(refer
                      to </span><a href="Database_Server/Accessing_Alliant%2c_SQL_Server%2c_and_Windows_Server_Applications/ Accessing_Alliant%2c_SQL_Server%2c_and_Windows_Server_Applications.htm">Accessing
                      Alliant, SQL Server, and Windows Server Applications</a> <span style="bookmark: _Ref392685365;">for
                      further information).</span></p><?rh-list_end ?>
                      <p class="List_Number_Image"><img src="image30.jpg" alt="" style="border: none;"
                                border="0" /></p>
                        class="List_Number">Expand <b style="bidi-font-weight: normal; color: #800080;">Services
                      and Applications</b>, expand <b style="bidi-font-weight: normal; color: #800080;">SQL
                      Server Configuration Manager</b>, expand <b style="bidi-font-weight: normal;
                                  color: #800080;">SQL Server
                      Network Configuration</b> and select <b style="bidi-font-weight: normal;
                                 color: #800080;">Protocols</b>
                      for <i style="bidi-font-style: normal;">ServerName</i>.
                      And here is the same section in the generated output:
                      p class="List_Number_Image"><span style="no-proof: yes;"><img src="../../../image27.jpg" alt="" style=" border:none; width:100%; max-width:550px;" border="0" /></span></p>
                      p
                      class="List_Number"><span class="rls-1-ML_List">3.</span><span style='word-spacing:normal; font:6.0pt "Times New Roman"'>    </span>Continue with the SQL Server Service Pack installation.<span
                      p
                      class="List_Number"><span class="rls-1-ML_List">4.</span><span style='word-spacing:normal; font:6.0pt "Times New Roman"'>    </span>When the SQL Server Service Pack installation
                      </p>
                      p class="List_Number_Image"><img src="../../../image28.jpg" alt="" style=" border:none; width:100%; max-width:548px;" border="0" /></p>
                      p class="List_Number rh-hide" data-rhtags="10"><span class="rls-1-ML_List">5.</span><span style='word-spacing:normal; font:6.0pt "Times New Roman"'>    </span>When you want to install Service Pack 2 (Service
                      p class="List_Number rh-hide" data-rhtags="10"><span class="rls-1-ML_List">6.</span><span style='word-spacing:normal; font:6.0pt "Times New Roman"'>    </span>Install Service Pack 2 (Service Pack 2 is required
                      p class="List_Number rh-hide" data-rhtags="10"><span class="rls-1-ML_List">7.</span><span style='word-spacing:normal; font:6.0pt "Times New Roman"'>    </span><span>When you want to install Service Pack 3
                      p class="List_Number rh-hide" data-rhtags="4"><span class="rls-1-ML_List">8.</span><span style='word-spacing:normal; font:6.0pt "Times New Roman"'>    </span>When you want to install Service Pack 2 (Service
                      p class="List_Number rh-hide" data-rhtags="2"><span class="rls-1-ML_List">9.</span><span style='word-spacing:normal; font:6.0pt "Times New Roman"'>    </span>Install Service Pack 2 (Service Pack 2 is required
                      <b style="bidi-font-weight: normal;" data-rhtags="2" class="rh-hide">repeat
                      </b> <b style="bidi-font-weight: normal;" data-rhtags="2" class="rh-hide">1</b>
                      <b style="bidi-font-weight: normal;" data-rhtags="2" class="rh-hide">through</b>
                      <b style="bidi-font-weight: normal;" data-rhtags="2" class="rh-hide">4</b>
                      <span style="spacerun: yes;" data-rhtags="2" class="rh-hide">&#160;</span></p>
                      p class="List_Number rh-hide" data-rhtags="4"><span class="rls-1-ML_List">10.</span><span style='word-spacing:normal; font:6.0pt "Times New Roman"'>  </span>When you want to install Service Pack 3 (Service
                      <b style="bidi-font-weight: normal;" data-rhtags="4" class="rh-hide">repeat steps</b>
                      <b style="bidi-font-weight: normal;" data-rhtags="4" class="rh-hide">1</b>
                      <b style="bidi-font-weight: normal;" data-rhtags="4" class="rh-hide">through</b>
                      <b style="bidi-font-weight: normal;" data-rhtags="4" class="rh-hide">4</b>
                      <span style="spacerun: yes;" data-rhtags="4" class="rh-hide">&#160;</span>&#160;Otherwise,
                      <b style="bidi-font-weight: normal;" data-rhtags="4" class="rh-hide">skip
                      </b> <b style="bidi-font-weight: normal;" data-rhtags="4" class="rh-hide">7</b>.</p>
                      p
                      class="List_Number"><span class="rls-1-ML_List">11.</span><span style='word-spacing:normal; font:6.0pt "Times New Roman"'>  </span><span style="bookmark: _Ref382406796;">Access
                      </span><a href="../../Accessing_Alliant,_SQL_Server,_and_Windows_Server_Applications/Accessing_Alliant,_ SQL_Server,_and_Windows_Server_Applications.htm">Accessing
                      </span></p>
                      p class="List_Number_Image"><img src="../../../image30.jpg" alt="" style=" border:none; width:100%; max-width:430px;" border="0" /></p>
                      p
                      class="List_Number"><span class="rls-1-ML_List">12.</span><span style='word-spacing:normal; font:6.0pt "Times New Roman"'>  </span>Expand <b style="bidi-font-weight: normal; color: #800080;">Services
                      SQL Server
                      Protocols</b>
                      • 8. Re: Numbered Lists with Dynamic Content Filtering
                        I'm seeing this code:
                        Are you by chance using the "Multi-Level" list here? If so, maybe that's what's nailing things. I'll have to test a bit on my end.
                        Cheers... Rick
                        • 9. Re: Numbered Lists with Dynamic Content Filtering
                          Maybe the multi-level list function has an impact - I don't know - never used it. Is your RH2015 install completely patched up?
                          • 10. Re: Numbered Lists with Dynamic Content Filtering
                            Yep, just tested on my end with a multi-numbered list. And in that list type, things go to pot!
                            Seems the fix is to avoid using that list type. Pretty easy to accomplish. Select first and last bit of list and click the multilevel icon. then simply apply numbers.
                            Cheers... Rick
                            • 11. Re: Numbered Lists with Dynamic Content Filtering
                              And then go file a bug report to get it on Adobe's radar ;>)
                              • 12. Re: Numbered Lists with Dynamic Content Filtering
                                Follow up. I tried manipulating the code in the editor. I noticed that the list code had the outer tagging pertaining to the list and the CBT tagging following that. So I tried rearranging the order in which they were listed. Made no difference I could see in the output. Things were still horked.
                                I'm thinking that you have discovered a hidden feature! Congratulations!
                                I'd suggest reporting it to Adobe.
                                Click here to file a bug report
                                Cheers... Rick
                                • 13. Re: Numbered Lists with Dynamic Content Filtering
                                  CN13579 Level 1
                                  Bummer. We pretty much need to keep it a multilevel list. I'll have to try to think of a workaround when I have more time.
                                  I've filed bug reports with adobe before and they've gone nowhere. I don't really think it's worth the time but if anyone else comes across this issue and wants to, feel free to use our examples.
                                  • 14. Re: Numbered Lists with Dynamic Content Filtering
                                    Actually, the bug reports do end up before the development team responsible for the product. I've filed bugs in the past where the dev team actually sent me follow up messages asking for more detail or sometimes advising that it isn't a bug and I should be using feature (X) instead of doing what I was doing.
                                    I'll be happy to file a bug report about this.
                                    Cheers... Rick
                                    • 16. Re: Numbered Lists with Dynamic Content Filtering
                                      CN13579 Level 1
                                      Could you post a link to the bug report for this so I can vote for it? This is an important issue for me. Thanks.
                                      • 17. Re: Numbered Lists with Dynamic Content Filtering
                                        You will need to obtain and use a login.
                                        Click here to view
                                        Cheers... Rick
                                        • 18. Re: Numbered Lists with Dynamic Content Filtering
                                          CN13579 Level 1
                                          I meant the specific bug listing for this issue, if you entered one as suggested above. If not, I'll go ahead and enter one.
                                          • 20. Re: Numbered Lists with Dynamic Content Filtering
                                            CN13579 Level 1
                                            Did adobe wipe out all their old bug reports? I went to check on this to see if they are going to fix it and it's nowhere to be found.
                                            • 21. Re: Numbered Lists with Dynamic Content Filtering
                                              What was wiped was your access. I do know they still internal access but
                                              that doesn't help you. There's a new bugbase. I'll add a link once I'm back
                                              on a PC.
                                              • 22. Re: Numbered Lists with Dynamic Content Filtering
                                                CN13579 Level 1
                                                Are they likely to fix this? We just upgraded to Robohelp 2017 and it's still broken. It seems like a pretty big flaw when dynamic content filtering is one of their big features now.
                                                • 23. Re: Numbered Lists with Dynamic Content Filtering
                                                  Looks like it's now called "Tracker" - Tracker - have a look & see if your issue in there...
                                                  • 24. Re: Numbered Lists with Dynamic Content Filtering
                                                    CN13579 Level 1
                                                    The search is not working for me now... It just spins endlessly. I do remember searching this new tracker before and not finding it which is why I asked if they wiped out all of their old bug reports.
                                                    I'm sincerely wondering if something happened at Adobe recently. We had a really hard time navigating their site to download the new applications and their communication and documentation seem to have taken a step down in quality.
                                                    • 25. Re: Numbered Lists with Dynamic Content Filtering
                                                      I just went to the bug base and selected RH as the product and then Execute Search at the bottom of the screen. Worked OK.
                                                      By Adobe standards, TechCommSuite is a relatively small product. Sadly it is easier if you use Google to find something on Adobe's site.
                                                      I don't think the documentation has changed too much other than being a responsive layout.
                                                      See www.grainge.org for RoboHelp and Authoring information
                                                      @petergrainge
                                                      • 26. Re: Numbered Lists with Dynamic Content Filtering
                                                        CN13579 Level 1
                                                        I recreated this bug (sort of) in the bug base. We're still waiting for this to be fixed. If anyone wants to vote for it, here's a link:
                                                        Tracker
