0 Replies Latest reply on Sep 23, 2016 3:40 AM by tpk1982
    Modification Date changed
    tpk1982 Level 4
      I am trying to create folders and copy the file what i pick. The below code is working fine in Indesign. I need this to work in Illustrator as well. Could you please help me?
      Original Thread: Modification Date changed
      function myfolder(){
          var _files = File.openDialog("Select Indesign/Illustrator file","*",true);
      if(_files==null){return;}
      myFolder = Folder.selectDialog("Choose Main folder to created subfolders");
      if(myFolder==null){return;}
      _parent = _files[0].parent.toString().replace(_files[0].parent.parent,"");
      var mygetname=prompt("Please enter the Event ID","");
      if(mygetname==null){return;}
      var myartname=prompt("Please enter the Part Number","");
      if(myartname==null){return;}
      var myartnamew=myartname+"_Aa"
      new Folder(myFolder + "/" + mygetname).create();
      new Folder(myFolder + "/" + mygetname+ "/OT"+ "/" + myartnamew).create();
      new Folder(myFolder + "/" + mygetname+ "/OT"+ "/" + myartnamew+ "/Art").create();
      new Folder(myFolder + "/" + mygetname+ "/OT"+ "/" + myartnamew +"/Soft").create();
      mymodified=_files[0].modified;
      myfile=new File(myFolder + "/" + mygetname+ "/OT"+ "/" + myartnamew+ "/Art"+ "/"+myartnamew+ "/" );
      _files[0].copy(new File(myFolder + "/" + mygetname+ "/OT"+ "/" + myartnamew+ "/Art"+ "/"+myartnamew+ "/" ));
      changeDate(myfile.fsName, mymodified);
      myfolder();
      function changeDate(file, date) {
          var year, month, dayOfMonth, hours, minutes, command, appleDate;
          year = 1900 + date.getYear();
          month = pad(1 + date.getMonth());
          dayOfMonth = pad(date.getDate());
          hours = pad(date.getHours());
          minutes = pad(date.getMinutes());
          appleDate = "" + year + month + dayOfMonth + hours + minutes;
          command = ["try",
              "do shell script \"touch -ft " + appleDate + " '" + file + "'\"",
              "end try"
          ].join('\n');
          try {
              app.doScript(command, ScriptLanguage.APPLESCRIPT_LANGUAGE);
          } catch (e) { $.writeln(command + "\n" + e); }
          return undefined;
          function pad(value, digits) {
              value = "" + value;
              digits = digits || 2;
              var padding = new Array(digits + 1).join("0");
              return (padding + value).slice(value.length);
      K
