23 Replies Latest reply on Oct 11, 2016 3:35 PM by DdeGannes
    Cannot export files to DVD/CD from Lightroom 6.6
    ericg73577250
      I am having an issue that I cannot export any of my pictures from Adobe Lightroom 6.6 to my CDE/DVD Burner.  LR goes through the motions of asking me which burner and what speed to burn and then prepares to burn that tries to start burning the disc and then immediately goes to 20% completed but there is no activity from my burner what so ever.  I know the burner works cause I also have a separate burner program I use regularly for other tasks.  I have tried exporting the files to a separate location on my hard drive and LR has no issue and performs the task flawlessly.  I have also uninstalled my burner software thinking there was a conflict rebooted my machine and LR still has the same issue exporting to the DVD/CD Burner.  Currently running Windows 7 64 bit, 16 gig of ram.  Any help would be appreciated.
        • 1. Re: Cannot export files to DVD/CD from Lightroom 6.6
          Tanuj Sandal Adobe Employee
          Hi Ericg,
          Could you please update Lightroom to 6.7 once and then check if it helps.
          Regards
          Tanuj
          • 2. Re: Cannot export files to DVD/CD from Lightroom 6.6
            ericg73577250 Level 1
            I have made the attempt and CC says I am currently up to date at 6.6.  I am running standalone LR.
            • 3. Re: Cannot export files to DVD/CD from Lightroom 6.6
              Try updating Lightroom from the following link: Keeping Lightroom Up-to-Date
              • 4. Re: Cannot export files to DVD/CD from Lightroom 6.6
                I was able to sucsessfully update to LR 6.7 but still having the same issue with burning to the CD/DVD.
                • 5. Re: Cannot export files to DVD/CD from Lightroom 6.6
                  Try exporting the files to a location on your computer and then try to burn the data to the disc using the disc burning software.
                  Also since when are you facing this issue?
                  • 6. Re: Cannot export files to DVD/CD from Lightroom 6.6
                    I have been able to burn the files from a separate location on my hard drive with my standalone burner program.  I am not sure how long this issues has been there since I have not tried until recently to burn files/photos directly from LR (i just have not had the need to do it until recently).  I realize that I can do this as a workaround but would like to solve this issue if possible instead of going around it.
                    • 7. Re: Cannot export files to DVD/CD from Lightroom 6.6
                      Thank you for the update, could you please check and create a test catalog, import some images in it and then check if you still face the same issue or not.
                      • 8. Re: Cannot export files to DVD/CD from Lightroom 6.6
                        I have made a test catalog imported some photos and attempted to export to CD.  LR goes through the motions and says it is burning to CD and I get the message "Adobe Photoshop Lightroom has stopped working" and I have to close the program.
                        • 9. Re: Cannot export files to DVD/CD from Lightroom 6.6
                          Could you please post the faulty module path for Lightroom crashing.
                          Check the link for how to collect the log from event viewer: Photoshop Elements Editor Help | How to Find Crash Logs on Windows
                          • 10. Re: Cannot export files to DVD/CD from Lightroom 6.6
                            I attempted to export twice here are the two errors:
                            1.
                            Log Name:      Application
                            Source:        Application Error
                            Date:          9/23/2016 2:04:48 PM
                            Event ID:      1000
                            Task Category: (100)
                            Level:         Error
                            Keywords:      Classic
                            User:          N/A
                            Computer:      Eric-PC
                            Description:
                            Faulting application name: lightroom.exe, version: 6.7.0.10, time stamp: 0x57dd74b0
                            Faulting module name: DiscBurning.dll, version: 6.7.0.10, time stamp: 0x57dd7455
                            Exception code: 0xc0000005
                            Fault offset: 0x000000000000943d
                            Faulting process id: 0xeb0
                            Faulting application start time: 0x01d215c4e54afc3e
                            Faulting application path: C:\Program Files\Adobe\Adobe Lightroom\lightroom.exe
                            Faulting module path: C:\Program Files\Adobe\Adobe Lightroom\DiscBurning.dll
                            Report Id: 36bb20b1-81b8-11e6-a4cb-240a641d265a
                            Event Xml:
                            <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
                              <System>
                                <Provider Name="Application Error" />
                                <EventID Qualifiers="0">1000</EventID>
                                <Level>2</Level>
                                <Task>100</Task>
                                <Keywords>0x80000000000000</Keywords>
                                <TimeCreated SystemTime="2016-09-23T18:04:48.000000000Z" />
                                <EventRecordID>92025</EventRecordID>
                                <Channel>Application</Channel>
                                <Computer>Eric-PC</Computer>
                                <Security />
                              </System>
                              <EventData>
                                <Data>lightroom.exe</Data>
                                <Data>6.7.0.10</Data>
                                <Data>57dd74b0</Data>
                                <Data>DiscBurning.dll</Data>
                                <Data>57dd7455</Data>
                                <Data>c0000005</Data>
                                <Data>000000000000943d</Data>
                                <Data>eb0</Data>
                                <Data>01d215c4e54afc3e</Data>
                                <Data>C:\Program Files\Adobe\Adobe Lightroom\lightroom.exe</Data>
                                <Data>C:\Program Files\Adobe\Adobe Lightroom\DiscBurning.dll</Data>
                                <Data>36bb20b1-81b8-11e6-a4cb-240a641d265a</Data>
                              </EventData>
                            </Event>
                            2.
                            Date:          9/23/2016 2:02:44 PM
                            Event ID:      1000
                            Level:         Error
                            Keywords:      Classic
                            User:          N/A
                            Computer:      Eric-PC
                            Description:
                            Faulting process id: 0x185c
                            Faulting application start time: 0x01d215c4103c3843
                            Report Id: ecd25cff-81b7-11e6-a4cb-240a641d265a
                            Event Xml:
                              <System>
                                <Level>2</Level>
                                <Task>100</Task>
                                <TimeCreated SystemTime="2016-09-23T18:02:44.000000000Z" />
                                <EventRecordID>92023</EventRecordID>
                                <Security />
                              </System>
                              <EventData>
                                <Data>185c</Data>
                                <Data>01d215c4103c3843</Data>
                                <Data>ecd25cff-81b7-11e6-a4cb-240a641d265a</Data>
                              </EventData>
                            </Event>
                            • 11. Re: Cannot export files to DVD/CD from Lightroom 6.6
                              As per the crash logs, it shows that the disc burning software is causing Lightroom to crash.
                              Could you please check if there is any update available for the software.
                              • 12. Re: Cannot export files to DVD/CD from Lightroom 6.6
                                I have checked the drivers for the DVD player and it states they are the current drivers.
                                • 13. Re: Cannot export files to DVD/CD from Lightroom 6.6
                                  This is the file that is causing Lightroom to crash, and it is from the disc burning application, try installing a previous version of the application.
                                  • 14. Re: Cannot export files to DVD/CD from Lightroom 6.6
                                    Flphotodoc
                                    I have a similar problem but with Rendering Slideshows to a Hard Disk.
                                    I am using LR6.7, Mac 5,1; 16 Gb RAM, OS X 10.11.6;   ATI Radeon HD5770 1 GB.
                                    This is a portion of what I get:
                                    Crashed Thread:        18
                                    Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
                                    Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000050
                                    Exception Note:        EXC_CORPSE_NOTIFY
                                    Thread 18 Crashed:
                                    0   com.adobe.mediacoreif.framework 0x00000001158493dd MediaCoreIF::VideoFrame::MapWritable(MCVideoFrameInfo&) + 13
                                    1   com.adobe.mediacoreif.framework 0x000000011587b890 MediaCoreIF::OffscreenSequenceRenderer::OnFrameRendered(MediaCoreIF::RenderSpanRequest&, MediaCoreIF::MCRenderStatus) + 1056
                                    2   com.adobe.mediacoreif.framework 0x000000011581932e MediaCoreIF::SequenceRenderSession::TrackRenderRequestDone(MediaCoreIF::RenderSpanRequest &, MediaCoreIF::MCRenderStatus) + 318
                                    3   com.adobe.mediacoreif.framework 0x000000011581d5e9 MediaCoreIF::TrackRenderSession::FrameReady(MediaCoreIF::RenderSpanRequest&, bool) + 281
                                    4   com.adobe.mediacoreif.framework 0x000000011581cc77 MediaCoreIF::FrameFillTask::Render(boost::shared_ptr<MediaCoreIF::FrameFillTask>, boost::shared_ptr<MediaCoreIF::TrackRenderSession>, bool) + 2519
                                    5   com.adobe.mediacoreif.framework 0x000000011581abbf MediaCoreIF::TrackRenderSession::RequestSpanData(boost::shared_ptr<MediaCoreIF::TrackRend erSession>, MediaCoreIF::RenderSpanRequest&, MediaCoreIF::MCMediaType) + 1519
                                    6   com.adobe.mediacoreif.framework 0x0000000115819d0c MediaCoreIF::SequenceRenderSession::RequestSpanData(MediaCoreIF::RenderSpanRequest&) + 2364
                                    7   com.adobe.mediacoreif.framework 0x000000011587b174 MediaCoreIF::OffscreenSequenceRenderer::StartVideoFrameRender(dvacore::utility::Guid const&, boost::rational<long long> const&, dynamiclink::VideoRenderOptions const&, dvacore::utility::Guid const&, dvacore::utility::Guid const&) + 916
                                    8   com.adobe.mediacoreif.framework 0x000000011587d396 MediaCoreIF::RenderSession::StartVideoFrameRender(dvacore::utility::Guid const&, boost::rational<long long> const&, dynamiclink::VideoRenderOptions const&) + 102
                                    9   com.adobe.dvacore.framework   0x0000000115d071ea dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 202
                                    10  com.adobe.dvacore.framework   0x0000000115d03b9e dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 158
                                    11  com.adobe.boost_threads.framework 0x0000000114306755 boost::(anonymous namespace)::thread_proxy(void*) + 133
                                    12  libsystem_pthread.dylib       0x00007fff9162e99d _pthread_body + 131
                                    13  libsystem_pthread.dylib       0x00007fff9162e91a _pthread_start + 168
                                    14  libsystem_pthread.dylib       0x00007fff9162c351 thread_start + 13
                                    Thanks in advance
                                    SGTraynor
                                    • 15. Re: Cannot export files to DVD/CD from Lightroom 6.6
                                      I removed the CD/DVD Driver rebooted the computer Win 7 automatically installed the driver again tried to export the files I been trying to do for the past several days and it works perfectly.  I am assuming there was a file corruption issue that has been fixed with the reinstallation of the driver.
                                      • 16. Re: Cannot export files to DVD/CD from Lightroom 6.6
                                        Thank you for sharing the solution that helped you.
                                        • 17. Re: Cannot export files to DVD/CD from Lightroom 6.6
                                          Tanuj,  Unfortunately I have more bad news.  When attempting to export to  a CD LR 6.7 attempts to prepare for export then just crashes.  Please see below for the log:
                                          Source:        Microsoft-Windows-Security-SPP
                                          Date:          10/10/2016 8:03:26 PM
                                          Event ID:      1003
                                          Task Category: None
                                          Level:         Information
                                          Keywords:      Classic
                                          User:          N/A
                                          Computer:      Admin-PC
                                          Description:
                                          The Software Protection service has completed licensing status check.
                                          Application Id=55c92734-d682-4d71-983e-d6ec3f16059f
                                          Licensing Status=
                                          1: 01f5fc37-a99e-45c5-b65e-d762f3518ead, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          2: 2e7d060d-4714-40f2-9896-1e4f15b612ad, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          3: 3b965dfc-31d9-4903-886f-873a0382776c, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          4: 586bc076-c93d-429a-afe5-a69fbc644e88, 1, 1 [(0 [0x00000000, 1, 0], [(?)(?)( 1 0x00000000 3 0 msft:rm/algorithm/hwid/4.0 0x00000000 0)(?)(?)(?)])(1 )(2 )]
                                          5: 5e017a8a-f3f9-4167-b1bd-ba3e236a4d8f, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          6: 5e35dc43-389b-47c5-b889-2088b06738cb, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          7: 6a7d5d8a-92af-4e6a-af4b-8fddaec800e5, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          8: 9ab82e0c-ffc9-4107-baa1-c65a8bd3ccc3, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          9: 9f83d90f-a151-4665-ae69-30b3f63ec659, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          10: a63275f4-530c-48a7-b0d3-4f00d688d151, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          11: b8a4bb91-69b1-460d-93f8-40e0670af04a, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          12: d2c04e90-c3dd-4260-b0f3-f845f5d27d64, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          13: e68b141f-4dfa-4387-b3b7-e65c4889216e, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          14: ee4e1629-bcdc-4b42-a68f-b92e135f78d7, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          15: 4a8149bb-7d61-49f4-8822-82c7bf88d64b, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          16: afd5f68f-b70f-4000-a21d-28dbc8be8b07, 1, 0 [(0 [0xC004F014, 0, 0], [(?)(?)(?)(?)(?)(?)])(1 )(2 )]
                                          Event Xml:
                                            <System>
                                              <Provider Name="Microsoft-Windows-Security-SPP" Guid="{E23B33B0-C8C9-472C-A5F9-F2BDFEA0F156}" EventSourceName="Software Protection Platform Service" />
                                              <EventID Qualifiers="16384">1003</EventID>
                                              <Version>0</Version>
                                              <Level>4</Level>
                                              <Task>0</Task>
                                              <Opcode>0</Opcode>
                                              <TimeCreated SystemTime="2016-10-11T00:03:26.000000000Z" />
                                              <EventRecordID>5352</EventRecordID>
                                              <Correlation />
                                              <Execution ProcessID="0" ThreadID="0" />
                                              <Computer>Admin-PC</Computer>
                                              <Security />
                                            </System>
                                            <EventData>
                                              <Data>55c92734-d682-4d71-983e-d6ec3f16059f</Data>
                                              <Data>
                                          </Data>
                                            </EventData>
                                          </Event>
                                          • 18. Re: Cannot export files to DVD/CD from Lightroom 6.6
                                            Tanuj,  I copied the wrong log sorry about that.  Below is the correct one..    Please see below for the log:
                                            Date:          10/10/2016 7:55:40 PM
                                            Event ID:      1000
                                            Level:         Error
                                            Keywords:      Classic
                                            User:          N/A
                                            Computer:      Admin-PC
                                            Description:
                                            Faulting process id: 0x44c
                                            Faulting application start time: 0x01d2235170263c7c
                                            Report Id: 0bd855ca-8f45-11e6-bf58-d850e6541dd8
                                            Event Xml:
                                              <System>
                                                <Level>2</Level>
                                                <Task>100</Task>
                                                <TimeCreated SystemTime="2016-10-10T23:55:40.000000000Z" />
                                                <EventRecordID>5345</EventRecordID>
                                                <Security />
                                              </System>
                                              <EventData>
                                                <Data>44c</Data>
                                                <Data>01d2235170263c7c</Data>
                                                <Data>0bd855ca-8f45-11e6-bf58-d850e6541dd8</Data>
                                              </EventData>
                                            </Event>
                                            • 19. Re: Cannot export files to DVD/CD from Lightroom 6.6
                                              It seems that Discburning.dll is causing Lightroom to crash.
                                              Could you please check with the disc burning software team and see if they can provide you with the most updated drivers.
                                              • 20. Re: Cannot export files to DVD/CD from Lightroom 6.6
                                                I am a little confused.  Do you mean disc burning software team at adobe?  If so how do I reach out to them?  Or do you mean the software maker that makes the independent disc burning software I own?
                                                • 21. Re: Cannot export files to DVD/CD from Lightroom 6.6
                                                  DdeGannes Adobe Community Professional
                                                  As far as I am aware Lightroom "per say" does not have a disk burning utility and uses the disk burning functions provided by your operating system.
                                                  • 22. Re: Cannot export files to DVD/CD from Lightroom 6.6
                                                    I have tried looking around for an alternate Win 7 64 bit driver for a super write master CD/DVD drive but have had no luck.
                                                    • 23. Re: Cannot export files to DVD/CD from Lightroom 6.6
                                                      If you require top quality disk burning functions then you may wish to purchase/acquire a dvd/cd burning application.
