5 Replies Latest reply on Feb 21, 2018 9:38 AM by beni27467886
    Cannot build Android: buildToolsVersion is not specified.
    jmartinezpena Level 1
      I've been working with build.phonegap.com with good results. However, the same code I used yesterday is not working today (I clicked Rebuild)
      It builds successfully for iOS and Windows, but not for Android. Here is the main part of the log:
      FAILURE: Build failed with an exception.
      * Where:
      Script '/project/CordovaLib/cordova.gradle' line: 128
      * What went wrong:
      A problem occurred evaluating root project 'project'.
      > No match found
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      Total time: 0.998 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      Failed to notify ProjectEvaluationListener.afterEvaluate(), but primary configuration failure takes precedence.
      java.lang.IllegalStateException: buildToolsVersion is not specified.
        at com.google.common.base.Preconditions.checkState(Preconditions.java:176)
