Hi, I've recently noticed a problem recently with Adobe Flash Player, as well as Adobe AIR, on my laptop. I have Windows 10, and I use an HP-brand laptop.
-HP Solutions refuses to run due to an error message "Solution Center has detected that you do not have the correct version of Adobe Flash Player for Internet Explorer installed." This should not be happening because I already checked what Adobe FP version I have on Internet Explorer and it's 23.0.0.162.
-As for Adobe AIR, multiple video games on my laptop have begun receiving the error message "This application requires a version of Adobe AIR which cannot be found."
- When I tried to install Adobe AIR, it also received the message "This application requires a version of Adobe AIR which cannot be found." I need Adobe AIR to install Adobe AIR?
I have already tried searching for solutions, and nothing appears. I have also tried uninstalling and reinstalling Flash. Coming here was my last resort.
<moderator edit: modified title to more accurately reflect issue>
Following links could be helpful
I'll escalate the issue with HP Solutions Center. Although, this may be an issue with HP Solutions Center. If you haven't done so, I recommend contacting them regarding this.
For the Adobe AIR issue, please post to the Adobe AIR forums.
Maria
Can you please try the following:
Does it work or still fail?
Yeah, this is a problem with HP Solutions Center. While Flash Player is a built-in component of Internet Explorer and Edge on Win10, it's a built-in component of those browsers, not a distinct application. It's not available for third-party applications to embed (at least not in the same way).
This has actually been the case since Windows 8.0 shipped, which is a couple years now. Given that this issue isn't new, I'm guessing the software is either at its end of life, a newer version of this software available that fixes this for current operating systems, or it's something that HP will need to remediate themselves by either fixing their detection logic on Win8 and higher and/or using alternate technology.
