1 Reply Latest reply on Sep 25, 2016 11:39 PM by Mylenium
    how to freeze a rodoscoped mask
    PremiereNoobSigh Level 1
      how do i freeze the frame of a rodoscoped mask
      ive been trying to select the frame i want, freezing it, and then masking the frame with pen tool and then turning off rodoscope, but the problem is it doesnt look perfectly the same due to using the pen tool to remask
        • 1. Re: how to freeze a rodoscoped mask
          Export a still image and re-import it or pre-compose and freeze frame. Rotobrush operates temporally and will always change its result after your change its input. That's just how it works. You need to learn to structure your work, which in most of your posts is the biggest issue (no offense). You're trying to do too much directly on a single footage layer.
