5 Replies Latest reply on Sep 27, 2016 3:36 AM by yorrd
    Relative URIs not supported - with an absolute URI
    yorrd
      I'm trying to achieve something alone these lines, downloading a file.
      new FileTransfer().download(
        downloadPath,
         "cdvfile://localhost/temporary/test/",
         (entry) => {
        console.log("done downloading to " + entry.toURL());
         true, // trustAllHosts
         {headers: {}}
      Testing is done on Android using the newest version of cordova, the file plugin and the file transfer plugin.
      The error (which I assume is because of the file path "cdvfile://localhost.../") is as follows
      E/PluginManager( 7657): Uncaught exception from plugin
      E/PluginManager( 7657): java.lang.IllegalArgumentException: Relative URIs are not supported.
          E/PluginManager( 7657):     at org.apache.cordova.CordovaResourceApi.assertNonRelative(CordovaResourceApi.java:452)
      E/PluginManager( 7657):     at org.apache.cordova.CordovaResourceApi.remapUri(CordovaResourceApi.java:135)
      E/PluginManager( 7657):     at org.apache.cordova.filetransfer.FileTransfer.download(FileTransfer.java:743)
      E/PluginManager( 7657):     at org.apache.cordova.filetransfer.FileTransfer.execute(FileTransfer.java:185)
      E/PluginManager( 7657):     at org.apache.cordova.CordovaPlugin.execute(CordovaPlugin.java:98)
      E/PluginManager( 7657):     at org.apache.cordova.PluginManager.exec(PluginManager.java:133)
      E/PluginManager( 7657):     at org.apache.cordova.CordovaBridge.jsExec(CordovaBridge.java:59)
      E/PluginManager( 7657):     at org.crosswalk.engine.XWalkExposedJsApi.exec(XWalkExposedJsApi.java:40)
      E/PluginManager( 7657):     at org.chromium.base.SystemMessageHandler.nativeDoRunLoopOnce(Native Method)
      E/PluginManager( 7657):     at org.chromium.base.SystemMessageHandler.handleMessage(SystemMessageHandler.java:37)
      E/PluginManager( 7657):     at android.os.Handler.dispatchMessage(Handler.java:102)
      E/PluginManager( 7657):     at android.os.Looper.loop(Looper.java:135)
      E/PluginManager( 7657):     at android.os.HandlerThread.run(HandlerThread.java:61)
      (from the adb logcat)
      I can't make any sense out of this because until now I believed, that the URI for the target directory I'm using, in fact IS an absolute one. Also, the docs suggest using the function just like I did.
      Thanks for any advice.
        • 1. Re: Relative URIs not supported - with an absolute URI
          kerrishotts Adobe Employee
          What version of Android are you testing on?
          Also, what does `downloadPath` look like?
          • 2. Re: Relative URIs not supported - with an absolute URI
            VectorP Level 4
            ...and what file-transfer plugin are you using (the file plugin is integrated and thus not separately needed)?
            It looks like you're using ancient plugins from the pgb repo.
            • 3. Re: Relative URIs not supported - with an absolute URI
              yorrd Level 1
              Android version is 5 (vanilla) with the crosswalk renderer. I thought there are no differences o.o
              downloadPath = "http://domain.com:12345/download/zipped/test.zip"
              • 4. Re: Relative URIs not supported - with an absolute URI
                yorrd Level 1
                I'm using meteor and added the plugin doing "meteor add cordova:cordova-plugin-file-transfer@1.6.0" and "cordova:cordova-plugin-file@4.3.0" which - to my knowledge - ist the last version, updated just 2 weeks ago.
                Until two minutes ago I didn't even know that there is a pgb repo
                • 5. Re: Relative URIs not supported - with an absolute URI
                  yorrd Level 1
                  VectorP kerrishotts
                  I just found this in the build logs when building the Android application. Is it related?
                  %% "cordova-plugin-compat" is required by (cordova-plugin-file) and cannot be removed (hint: use -f or --force) and cannot be removed (hint: use -f or --force)
                  (node) warning: possible EventEmitter memory leak detected. 11 error listeners added. Use emitter.setMaxListeners() to increase limit.
                  Trace
                      at TLSSocket.addListener (events.js:239:17)
                      at TLSSocket.Readable.on (_stream_readable.js:680:33)
                      at Request.<anonymous> (/home/git/.meteor/packages/meteor-tool/.1.4.1_1.275oit++os.linux.x86_64+web.browser+web. cordova/mt-os.linux.x86_64/dev_bundle/lib/node_modules/cordova-lib/node_modules/npm/node_m odules/npm-registry-client/lib/request.js:153:7)
                      at emitOne (events.js:77:13)
                      at Request.emit (events.js:169:7)
                      at ClientRequest.<anonymous> (/home/git/.meteor/packages/meteor-tool/.1.4.1_1.275oit++os.linux.x86_64+web.browser+web. cordova/mt-os.linux.x86_64/dev_bundle/lib/node_modules/cordova-lib/node_modules/npm/node_m odules/request/request.js:791:10)
                      at emitOne (events.js:82:20)
                      at ClientRequest.emit (events.js:169:7)
                      at tickOnSocket (_http_client.js:523:7)
                      at onSocketNT (_http_client.js:535:5)
                      at nextTickCallbackWith2Args (node.js:442:9)
                      at process._tickCallback (node.js:356:17)
