3 Replies Latest reply on Sep 28, 2016 5:21 AM by Nanaky
    Adobe ID
    will77437670
      Just changed the email address for my Adobe Digital Editions en had it verified. Nevertheless when I use the 'new' Adobe ID it says 'you can only authorise your computer with an Adobe ID that hasn't been used for the authorisation of a computer or a mobile device. Try again.'
      So the question is 'how can I get an Adobe ID that wil work.......'
      Thanks in advance,
      Wil
      you can send me an email at [email removed -- no personal info allowed on forum]
        • 1. Re: Adobe ID
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
          • 2. Re: Adobe ID
            will77437670 Level 1
            Thank you very much for your advice. I'll apply it one of these days and will inform you about the result!
            Wil
            • 3. Re: Adobe ID
              Nanaky Level 5
              Good Luck.
