5 Replies Latest reply on Apr 22, 2017 6:50 AM by andersons2058306
    Translation form
    andersons2058306 Level 1
      1. Hello.
      I have a question to translate a form using XLIFF.
      1 – LiveCycle - In the menu Tool / Options in Document Handing I enabled the option Creat Translation IDs When Saving.
      2 - I worked in a file that I have to translate. In follow I saved the file with the name of B with the XDP extension.
      3 - Within the Cmd, C: \ Users \ Anderson \ FormTranslation
      I typed the command java -jar saxon9.jar B.xdp extractstrings.xslt> B.s2x
      And then I got B.s2x file.
      4 - Then I opened the file in B.s2x in the  SwordFish program to translate. In this program I translated the English language for the Portuguese language. Then I saved this file B.s2x translated.
      5 - After the Cmd I typed the command
      java -jar saxon9.jar B.s2x mergestrings.xslt xdpFile B.xdp => BTranslated.xdp
      So I got the BTranslated.xdp file. But when I opened the file in LiveCycle BTranslated.xdp this is not translated. I cannot understand why.
      Comments. In step 4 when I translated the B.s2x file by SwordFish program, I opened the file with the B.s2x Notpad and made sure it was translated.
      I realized that supposedly the problem is after the command Cmd in the java -jar saxon9.jar B.s2x mergestrings.xslt xdpFile B.xdp => BTranslated.xdp the file is not converted with the translation.
      I put these files in the link, if someone can help me. After all process I changed the file names for you to understand what the original files and which translated form.
      If anyone can help me I thank you.
      Files,
      WeTransfer
        • 1. Re: Translation form
          Finally I was able to solve the problem.
          The problem was in the mergestrings file.
          I use the latest version of Adobe LiveCycle. That is, I used the mergestrings file that came in this release.
          But I discovered that the error is at line 66 of this file.
          <Xslt: variable name = "translatedNode" select = "$ s2x [@ id = $ idToGet] [1] / target" />
          I installed the LiveCycle ES2 version on another computer. So I took the mergestrings file from this version.
          When I compare the two files I noticed the error is on line 66.
          ES4 - <xslt: variable name = "translatedNode" select = "$ s2x [@ id = $ idToGet] [1] / target" />
          ES2 - <xslt: variable name = "idToGet" select = "@ xliff: rid" />
          Select = "$ s2x [@ id = $ idToGet] [1] / source" />
          After changing the mergestrings file and executing the command in ProntCmd (java -jar saxon8.jar myform.s2x mergestrings.xslt xdpFile = myform.xdp> myformtranslate.xdp) I got the file translated  in LiveCycle.
          • 2. Re: Translation form
            sujoyn3456561
            While executing the command getting the following error, can u plz help me out
            • 3. Re: Translation form
              Hello.
              I will help you.
              But, my focus will in procees and not in error reported by you.
              1 – Copy that files to inside de folder thas has de files for translation.
              For exemplo: in my case the folder is C:\TranslateForms.
              Put that files “mergestrings.xslt” and “extractstrings.xslt” inside the folder
              “TranslateForms”.
              2 - In LiveCycle Design, from the “Tools TAB” – “Options|Document Handling” select
              “Create Translation ID’s when saving”.
              3- Now you need to open the file for translation or create a file for translation.
              And the next step is save form as extension XDP.
              4. Open command prompt and make sure you cd to: C:\TranslateForms
              5. Type the following command
              java -jar saxon8.jar MYFILE.xdp extractstrings.xslt > MYFILE.s2x
              6– After that command you get the file .s2x
              I don’t what version LiveCycle you are using and if you put the files from step 1 inside the folder for translation.
              I hope that help you.
              If you don’t get the file .s2x let me know.
              Files:
              extractstrings.xslt - Google Drive
              mergestrings.xslt - Google Drive
              • 4. Re: Translation form
                Sorry,  after step 1 I forgot that step:
                You need put the Saxon8.jar or Saxon9.jar  inside the folder C:\TranslateForms
                Unpack the Saxon.
                saxon8.jar.zip - Google Drive
                • 5. Re: Translation form
                  If you use Saxon 8 the command is:
                  If you use Saxon 9 the command is:
                  java -jar saxon9.jar MYFILE.xdp extractstrings.xslt > MYFILE.s2x
