6 Replies Latest reply on Sep 26, 2016 9:41 PM by tpk1982
    FindChangeByList.jsx ?
    cbishop01 Level 2
      Can someone post the FindChangeByList.jsx that came with Indesign?  Mine for some reason is giving me errors.
        • 1. Re: FindChangeByList.jsx ?
          tpk1982 Level 4
          //FindChangeByList.jsx
          //An InDesign CS6 JavaScript
          @@@BUILDINFO@@@ "FindChangeByList.jsx" 3.0.0 15 December 2009
          //Loads a series of tab-delimited strings from a text file, then performs a series
          //of find/change operations based on the strings read from the file.
          //The data file is tab-delimited, with carriage returns separating records.
          //The format of each record in the file is:
          //findType<tab>findProperties<tab>changeProperties<tab>findChangeOptions<tab>description
          //Where:
          //<tab> is a tab character
          //findType is "text", "grep", or "glyph" (this sets the type of find/change operation to use).
          //findProperties is a properties record (as text) of the find preferences.
          //changeProperties is a properties record (as text) of the change preferences.
          //findChangeOptions is a properties record (as text) of the find/change options.
          //description is a description of the find/change operation
          //Very simple example:
          //text {findWhat:"--"} {changeTo:"^_"} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false} Find all double dashes and replace with an em dash.
          //More complex example:
          //text {findWhat:"^9^9.^9^9"} {appliedCharacterStyle:"price"} {include footnotes:true, include master pages:true, include hidden layers:true, whole word:false} Find $10.00 to $99.99 and apply the character style "price".
          //All InDesign search metacharacters are allowed in the "findWhat" and "changeTo" properties for findTextPreferences and changeTextPreferences.
          //If you enter backslashes in the findWhat property of the findGrepPreferences object, they must be "escaped"
          //as shown in the example below:
          //{findWhat:"\\s+"}
          //For more on InDesign scripting, go to http://www.adobe.com/products/indesign/scripting/index.html
          //or visit the InDesign Scripting User to User forum at http://www.adobeforums.com
          main();
          function main(){
            var myObject;
            //Make certain that user interaction (display of dialogs, etc.) is turned on.
            app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
            if(app.documents.length > 0){
            if(app.selection.length > 0){
            switch(app.selection[0].constructor.name){
            case "InsertionPoint":
            case "Character":
            case "Word":
            case "TextStyleRange":
            case "Line":
            case "Paragraph":
            case "TextColumn":
            case "Text":
            case "Cell":
            case "Column":
            case "Row":
            case "Table":
            myDisplayDialog();
            break;
            default:
            //Something was selected, but it wasn't a text object, so search the document.
            myFindChangeByList(app.documents.item(0));
            else{
            //Nothing was selected, so simply search the document.
            else{
            alert("No documents are open. Please open a document and try again.");
          function myDisplayDialog(){
            var myObject;
            var myDialog = app.dialogs.add({name:"FindChangeByList"});
            with(myDialog.dialogColumns.add()){
            with(dialogRows.add()){
            with(dialogColumns.add()){
            staticTexts.add({staticLabel:"Search Range:"});
            var myRangeButtons = radiobuttonGroups.add();
            with(myRangeButtons){
            radiobuttonControls.add({staticLabel:"Document", checkedState:true});
            radiobuttonControls.add({staticLabel:"Selected Story"});
            if(app.selection[0].contents != ""){
            radiobuttonControls.add({staticLabel:"Selection", checkedState:true});
            var myResult = myDialog.show();
            if(myResult == true){
            switch(myRangeButtons.selectedButton){
            case 0:
            myObject = app.documents.item(0);
            break;
            case 1:
            myObject = app.selection[0].parentStory;
            break;
            case 2:
            myObject = app.selection[0];
            break;
            myDialog.destroy();
            myFindChangeByList(myObject);
            else{
            myDialog.destroy();
          function myFindChangeByList(myObject){
            var myScriptFileName, myFindChangeFile, myFindChangeFileName, myScriptFile, myResult;
            var myFindChangeArray, myFindPreferences, myChangePreferences, myFindLimit, myStory;
            var myStartCharacter, myEndCharacter;
            var myFindChangeFile = myFindFile("/FindChangeSupport/FindChangeList.txt")
            if(myFindChangeFile != null){
            myFindChangeFile = File(myFindChangeFile);
            var myResult = myFindChangeFile.open("r", undefined, undefined);
            //Loop through the find/change operations.
            do{
            myLine = myFindChangeFile.readln();
            //Ignore comment lines and blank lines.
            if((myLine.substring(0,4)=="text")||(myLine.substring(0,4)=="grep")||(myLine.substring(0, 5)=="glyph")){
            myFindChangeArray = myLine.split("\t");
            //The first field in the line is the findType string.
            myFindType = myFindChangeArray[0];
            //The second field in the line is the FindPreferences string.
            myFindPreferences = myFindChangeArray[1];
            //The second field in the line is the ChangePreferences string.
            myChangePreferences = myFindChangeArray[2];
            //The fourth field is the range--used only by text find/change.
            myFindChangeOptions = myFindChangeArray[3];
            switch(myFindType){
            case "text":
            myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
            break;
            case "grep":
            myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
            break;
            case "glyph":
            myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions);
            break;
            } while(myFindChangeFile.eof == false);
            myFindChangeFile.close();
          function myFindText(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
            //Reset the find/change preferences before each search.
            app.changeTextPreferences = NothingEnum.nothing;
            app.findTextPreferences = NothingEnum.nothing;
            var myString = "app.findTextPreferences.properties = "+ myFindPreferences + ";";
            myString += "app.changeTextPreferences.properties = " + myChangePreferences + ";";
            myString += "app.findChangeTextOptions.properties = " + myFindChangeOptions + ";";
            app.doScript(myString, ScriptLanguage.javascript);
            myFoundItems = myObject.changeText();
            //Reset the find/change preferences after each search.
          function myFindGrep(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
            //Reset the find/change grep preferences before each search.
            app.changeGrepPreferences = NothingEnum.nothing;
            app.findGrepPreferences = NothingEnum.nothing;
            var myString = "app.findGrepPreferences.properties = "+ myFindPreferences + ";";
            myString += "app.changeGrepPreferences.properties = " + myChangePreferences + ";";
            myString += "app.findChangeGrepOptions.properties = " + myFindChangeOptions + ";";
            var myFoundItems = myObject.changeGrep();
            //Reset the find/change grep preferences after each search.
          function myFindGlyph(myObject, myFindPreferences, myChangePreferences, myFindChangeOptions){
            //Reset the find/change glyph preferences before each search.
            app.changeGlyphPreferences = NothingEnum.nothing;
            app.findGlyphPreferences = NothingEnum.nothing;
            var myString = "app.findGlyphPreferences.properties = "+ myFindPreferences + ";";
            myString += "app.changeGlyphPreferences.properties = " + myChangePreferences + ";";
            myString += "app.findChangeGlyphOptions.properties = " + myFindChangeOptions + ";";
            var myFoundItems = myObject.changeGlyph();
            //Reset the find/change glyph preferences after each search.
          function myFindFile(myFilePath){
            var myScriptFile = myGetScriptPath();
            var myScriptFile = File(myScriptFile);
            var myScriptFolder = myScriptFile.path;
            myFilePath = myScriptFolder + myFilePath;
            if(File(myFilePath).exists == false){
            //Display a dialog.
            myFilePath = File.openDialog("Choose the file containing your find/change list");
            return myFilePath;
          function myGetScriptPath(){
            try{
            myFile = app.activeScript;
            catch(myError){
            myFile = myError.fileName;
            return myFile;
          • 2. Re: FindChangeByList.jsx ?
            tpk1982 Level 4
            • 3. Re: FindChangeByList.jsx ?
              cbishop01 Level 2
              Thank you
              • 4. Re: FindChangeByList.jsx ?
                cbishop01 Level 2
                IT still gives me an error on line 173   does it work for you?
                • 5. Re: FindChangeByList.jsx ?
                  tpk1982 Level 4
                  Yes it is working, and this will work depends on the txt file called "FindChangeList.txt" inside the folder FindChangeSupport
