When I run the following command
adobe_prtk.exe --tool=VolumeSerialize --generate --serial="XXXX-XXXX-XXXX-XXXX-XXXX-XXXX" --leid="V7{}AcrobatESR-12-Win-GM" --regsuppress=ss --eulasuppress
I'm getting return code = 19.
Only thing I see on that code is this
19 | The provXML is missing |
Which makes no sense in this case since I'm trying to generate the file so of course it is missing.
Not sure were to go from here. This is for a xenapp 7.7 on windows 2012 R2 deployment.
I found an updated version of aptee and then the process worked. first link I clicked from a forum post must have been old.
7.7 is not supported yet. See Citrix XenApp — Enterprise Administration Guide.
Doesn't mean it won't work, only that it's not supported or tested. See also Common Deployment Options and Methods — Enterprise Administration Guide.
I think you need to specify --provfilepath=<Absolute path to prov.xml>
HTH
