7 Replies Latest reply on Sep 27, 2016 9:07 AM by tpk1982
    Help Changing Fonts.
    cbishop01 Level 2
      I'm using the below code.  I'm trying to replace a few fonts that are in Paragraph and Character styles.
        function cb7CallBack(target) {
         var docs = app.documents;
            for (var d = docs.length-1; d >= 0; d--) {
         var doc=docs[d];
         var BOLD = doc.characterStyles;
            for (var a = 0; a < BOLD.length; a++) {
         if (BOLD[a].appliedFont=="Helvetica Neue LT Pro" && BOLD[a].fontStyle =="77 Bold Condensed") {
           BOLD[a].appliedFont = "Suisse Int'l Condensed"
           BOLD[a].fontStyle = "Bold"
         var doc=docs[d];
         var REG = doc.characterStyles;
           for (var a = 0; a < REG.length; a++) {
         if (REG[a].appliedFont=="Helvetica Neue LT Pro" && REG[a].fontStyle =="57 Condensed") {
           REG[a].appliedFont = "Suisse Int'l Condensed"
           REG[a].fontStyle = "Regular"
        • 1. Re: Help Changing Fonts.
          Skemicle Level 3
          Font styles such as bold italic reguler, etc are classified as part of the font name: so to set a font you would use "Arial\tBold" to get the Bold style of Arial. and for the size of the text you would use pointSize rather than fontStyle.. so to make a selection have a size of 32 you would use: app.activeDocument.selection[0].pointSize = "32pt"
          • 2. Re: Help Changing Fonts.
            cbishop01 Level 2
            I should clarify.  The First part of the code works.  "BOLD"  I cannot get the second part to work.
            • 3. Re: Help Changing Fonts.
              tpk1982 Level 4
              Hope it works, also no need use document length twice..try this
              function cb7CallBack() {
                     var doc=docs[d];
                                    for (var a = BOLD.length-1; a >= 0; a--) {
                                            if (BOLD[a].appliedFont=="Helvetica Neue LT Pro" && BOLD[a].fontStyle =="57 Condensed") {
                                              BOLD[a].fontStyle = "Regular"
              cb7CallBack()
              • 4. Re: Help Changing Fonts.
                Peter Kahrel Adobe Community Professional & MVP
                Are you sure that Suisse Int'l Condensed has a Regular font? Somehow Condensed and Regular seem to contradict each other.
                • 5. Re: Help Changing Fonts.
                  cbishop01 Level 2
                  Yes.  There is a Suisse int'l Reg and Suisse int'l Condensed Regular.
                  • 6. Re: Help Changing Fonts.
                    cbishop01 Level 2
                    UnFortunately No.  It will only changes the 77 Bold COND.  and leaves 57 Cond alone.  I'm guessing because the 57 is in a paragraphStyle.  I've changed characterStyles to paragraphStyle just to see if it would work and it still doesnt.
                    • 7. Re: Help Changing Fonts.
                      tpk1982 Level 4
                      The provided coding only for character style
