6 Replies Latest reply on Sep 9, 2017 11:26 PM by iwaddo77
    Lightroom 5: How do I delete a folder?
    rkbroder
      How do I add photos to an existing folder? Whenever I try to do it, it creates a sub-folder, which I do not want.
        • 1. Re: Lightroom 5: How do I delete a folder?
          dj_paige Level 10
          Move (not Copy) photos to a folder: drag and drop
          Delete a folder: right-click on it, select Delete
          • 2. Re: Lightroom 5: How do I delete a folder?
            Abambo Adobe Community Professional
            How do you proceed? give screen shots.
            By default, you import photos into a base directory, which creates a directory with the current year as name and then creates a directory with the shooting date. There it puts the imported pictures. If the directories exist, the files are only added.
            If however you change the base directory, a new year/date structure is created, even if it exists in the old directory tree. LR can hide the base directory path, so you may have the impression, that a directory exists twice in the tree.
            • 3. Re: Lightroom 5: How do I delete a folder?
              Just Shoot Me Adobe Community Professional
              This is a setting in the Import dialog window in the Destination area. Look at and read all the options that are available in that area. Select the ones you want, don't select the ones you don't want.
              • 4. Re: Lightroom 5: How do I delete a folder?
                rkbroder Level 1
                Thank you. However, when I right click to delete a folder, I get a message below. Can I completely remove the folder?Untitled.png
                • 5. Re: Lightroom 5: How do I delete a folder?
                  LR doesn't Delete folders, IIRC, it only removes them from the catalog. To completely remove a folder from your hard drive and the LR catalog first remove it from LR then using your operating systems file manager delete it. NOTE that using the file manager will also delete all images, files, inside of that folder. That is why you should first remove it from the LR catalog.
                  • 6. Re: Lightroom 5: How do I delete a folder?
                    iwaddo77 Level 1
                    "LR doesn't Delete folders, IIRC, it only removes them from the catalog." Is no longer a valid statement as in my experience LR does delete the folder from the disk if the folder is empty.
                    I've searched the manual which also states that LR will not delete the folder from the disk. What is the best way to get Adobe to amend the manual, as it should say, 'unless the folder on the disk is empty'.
                    I'm not sure which behaviour users will prefer but for me this exactly what I wanted to happen.
                    How to create and manage folders in Photoshop Lightroom
                    Delete folders
                    • In the Folders panel of the Library module, select one or more folders and click the Minus icon (-). Or, right-click (Windows) or Control-click (Mac OS) and choose Remove.
                      Click Continue in the dialog box.
                      The folder and its photos are removed from the catalog and the Folders panel. The original folder and photos are not deleted from the hard drive.
