5 Replies Latest reply on Sep 29, 2016 6:30 AM by Szalam
    All Versions of AE crashing on startup.
    Gutterfish Adobe Community Professional
      While using AE 13.2 I dragged an image from the project panel to the work area and AE crashed.  No big deal, this happens sometimes.
      The error said something about dynamic link with Premier which I thought was weird as i do not use Premier and don't even have it installed.
      I went through the usual process of saving a file under a new name before AE stopped (nice feature)  but when I tried to restart AE I got this error:
      "After EFfects error: Crash in progress. Last logged message was <6680> <ae.blitpipe> <2>. Making New Context"
      I tried opening several thing, different projects...still crash.
      I tried opening in other newer versions of AE...nope.
      I tried resetting preference on startup.
      I tried going into AppData folder to delete the preference manually but there are over twenty After Effects folders in the main Adobe folder (many with unicode markings)
      I tried rebooting.
      Finally I uninstalled all versions of AE including the Preference files and then reinstalled only 2014 (13.2) and it still immediately crashes on startup.
      I was going to go directly to Adobe support but since I cannot do that until tomorrow morning I figured posting here couldn't hurt.
      I'm using windows10.
      I've using AE everyday for years and did nothing unusual.
      I did install a couple of camera raw updates yesterday which updated 2015 and 2014 but I was using AE for about 10 minutes successfully
      before I tried to drag the image (which was used in other places in the project and other projects) to the work area and the crash happened.
      Any suggestions are appreciated as, for the first time in two years, I cannot do my job.
        • 1. Re: All Versions of AE crashing on startup.
          So an update.   I managed to open After Effects by double clicking a very old project file from over a year ago. (could not open it by clicking app shortcut).
          Once I did I was able to open the project file that crashed (pre-crash version) I followed the same exact steps that led to the crash:
          I dragged the .ai image from Bridge to the project panel.
          I dragged the .ai file from the project panel to the work area.
          I enable continuous raster
          I hit "s" to open scale properties
          I dragged the scale value and the crash happened
          (I know in my first post I said it crashed when it got dragged to the timeline but that was a mistake.  It crashed when I tried to scale)
          The errpr I got this time was:
          <syncservice> <4> Check Connection: 3
          So now that the crash happened again AE would not start again. Same as when I first posted.
          So I opened the old project again that had worked at the top of this post.
          From there I opened the current project that keeps crashing.
          This time I followed the same exact steps except with a different .ai file (to try and isolate a problem)
          With a different .ai file there was no crash when I tried to scale.
          So I went through steps again using the .ai file that was causing the crash but this time no crash.
          Now everything is back to normal (except my preferences are reset).
          I can open AE via the app shortcut again and I am working no problem.
          Weird?
          • 2. Re: All Versions of AE crashing on startup.
            FFS...Scaling that footage just crashed AE again.!!!
            Error: <Dynamic Link> <5> C:\Program Files\Adobe\Adobe Premier Pro CC2014
            That file path does not even exist on computer!!  WTH is going on?
            • 3. Re: All Versions of AE crashing on startup.
              The problem is random and seems isolated to vector files.  Not consistently but often changing transform properties (scale or position so far) on a .ai or an .eps file causes the crash.  Sometimes it does sometimes it doesn't.  Also seems something happened to my bridge application and it would not return any search results at all.  I had to reset prefs and then still I had to manually open up every folder that I wanted to be included in searches before Bridge would return results from that folder.  I think I might be having chest pains.
              • 4. Re: All Versions of AE crashing on startup.
                Well, all the talk I've heard about Adobe Support being terrible doesn't match my experience today.  Call was answered within a minute or two and dude spent two hours remotely trouble shooting my issue.  One we identified the problem, which was some freak of a bad driver release from Ugee and the weird Camera Raw update glitch that for whatever reason wreaked havok, I was able to get everything working correctly.
                • 5. Re: All Versions of AE crashing on startup.
                  Thank you for sharing what worked!
