1 Reply Latest reply on Sep 27, 2016 9:37 AM by MrBen1909
    Windows Build 0x80070002 (WIN32: 2 ERROR_FILE_NOT_FOUND)
    MrBen1909 Level 1
      I am currently trying to build a new windows package from the build.adobe.com and get the following message.
      CertUtil: -importPFX command FAILED: 0x80070002 (WIN32: 2 ERROR_FILE_NOT_FOUND)
      This has worked previously with this certificate so I am at a loss to the cause. I have tried deleting and reinstalling the certificate and changing the title of the key to match the filename and all other suggestions that I can find related to this issue on the forums. So I am at abit of a loss.
      App ID is 2207379
        • 1. Re: Windows Build 0x80070002 (WIN32: 2 ERROR_FILE_NOT_FOUND)
          MrBen1909 Level 1
          Tried another build this morning, I still get the above error. I have attached the log file below. Any ideas?
          Build Date: 2016-09-27 16:33:10 +0000
          ================ Certificate 0 ================
          ================ Begin Nesting Level 1 ================
          Element 0:
          Serial Number: a8d20dfdf3426a8a48e5130c3d75475e
          Issuer: CN=CN=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
          NotBefore: 9/27/2016 4:28 PM
          NotAfter: 1/1/2020 7:00 AM
          Subject: CN=CN=xxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
          Signature matches Public Key
          Root Certificate: Subject matches Issuer
          Cert Hash(sha1): 87 30 ef e8 c0 f0 39 92 bc 55 71 af aa 8c 07 85 5c d1 20 27
          ---------------- End Nesting Level 1 ----------------
            Provider = Microsoft Strong Cryptographic Provider
          Signature test passed
          CertUtil: -dump command completed successfully.
          PLUGIN OUTPUT
          Fetching plugin "cordova-plugin-battery-status@~1.1.1" via npm
          Installing "cordova-plugin-battery-status" at "1.1.2" for windows
          Fetching plugin "cordova-plugin-camera@~2.1.1" via npm
          Installing "cordova-plugin-camera" at "2.1.1" for windows
          Fetching plugin "cordova-plugin-media-capture@~1.2.0" via npm
          Installing "cordova-plugin-media-capture" at "1.2.0" for windows
          Fetching plugin "cordova-plugin-file" via npm
          Installing "cordova-plugin-file" at "4.3.0" for windows
          Fetching plugin "cordova-plugin-compat" via npm
          Installing "cordova-plugin-compat" at "1.0.0" for windows
          The Android Persistent storage location now defaults to "Internal". Please check this plugins README to see if you application needs any changes in its config.xml.
          If this is a new application no changes are required.
          If this is an update to an existing application that did not specify an "AndroidPersistentFileLocation" you may need to add:
            "<preference name="AndroidPersistentFileLocation" value="Compatibility" />"
          to config.xml in order for the application to find previously stored files.
          Fetching plugin "cordova-plugin-console@~1.0.2" via npm
          Installing "cordova-plugin-console" at "1.0.4" for windows
          Fetching plugin "cordova-plugin-contacts@~2.0.1" via npm
          Installing "cordova-plugin-contacts" at "2.0.1" for windows
          Fetching plugin "cordova-plugin-device@~1.1.1" via npm
          Installing "cordova-plugin-device" at "1.1.3" for windows
          Fetching plugin "cordova-plugin-device-motion@~1.2.0" via npm
          Installing "cordova-plugin-device-motion" at "1.2.2" for windows
          Fetching plugin "cordova-plugin-device-orientation@~1.0.2" via npm
          Installing "cordova-plugin-device-orientation" at "1.0.4" for windows
          Fetching plugin "cordova-plugin-dialogs@~1.2.0" via npm
          Installing "cordova-plugin-dialogs" at "1.2.1" for windows
          Plugin "cordova-plugin-file" already installed on windows. Making it top-level.
          Fetching plugin "cordova-plugin-file-transfer@~1.5.0" via npm
          Installing "cordova-plugin-file-transfer" at "1.5.1" for windows
          Dependent plugin "cordova-plugin-file" already installed on windows.
          Fetching plugin "cordova-plugin-globalization@~1.0.3" via npm
          Installing "cordova-plugin-globalization" at "1.0.4" for windows
          Fetching plugin "cordova-plugin-inappbrowser@~1.3.0" via npm
          Installing "cordova-plugin-inappbrowser" at "1.3.0" for windows
          Fetching plugin "cordova-plugin-media@~2.2.0" via npm
          Installing "cordova-plugin-media" at "2.2.0" for windows
          Fetching plugin "cordova-plugin-network-information@~1.2.0" via npm
          Installing "cordova-plugin-network-information" at "1.2.1" for windows
          Fetching plugin "cordova-plugin-statusbar@~2.1.2" via npm
          Installing "cordova-plugin-statusbar" at "2.1.3" for windows
          Fetching plugin "cordova-plugin-whitelist@~1.2.1" via npm
          Installing "cordova-plugin-whitelist" at "1.2.2" for windows
          CertUtil: The system cannot find the file specified.
          My "Personal"
          CertUtil: -delstore command completed successfully.
