1 Reply Latest reply on Sep 26, 2016 11:46 PM by Willi Adelberger
    ID CC2015 can not display data from idml file export form it own
    Duy-NV-Niteco
      Hello,
      I meet a problem with idml file on CC 2015
      After i exported an indd file from CC 2015
      I opened it on CC 2014 and it opens with all data.
      But when i reopen it on CC 2015, the file is not fully displayed.
      Does anyone met this problem before?
        • 1. Re: ID CC2015 can not display data from idml file export form it own
          Jumping between versions causes always problems. If you collaborate with others or yourself you should always stay in the very same version. Not every feature in an older version is supported. Opening in the older version causes always damage to the file. And you will experience it there and when going back to the newer version.
          Starting in an older version and working on in the later one causes normally fewer problems, even there some oddities can appear as older bugs are repaired or some functionalities have been improved or changed to guarantee compatibility to new functions.
