1 Reply Latest reply on Sep 28, 2016 6:17 AM by FergyMac
    InDesign crashes when updating linked files
    FergyMac Level 3
      Using the links pallet to open an Illustrator or Photoshop file, edit it and save it, return to InDesign, InDesign will crash every time. Reopen InDesign the link will show as being modified (yellow triangle with exclamation mark). I can then update the link and continue working.
      InDesign CC2015.4
      11.4.1.102 Build
      Mac OS X 10.11.6
      MacBook Pro
      2.8 GHz Intel Core i7
      16 GB ram
      AMD Radeon R9 M379X 2043 MB
      No change in behavior after replacing my preferences.
        • 1. Re: InDesign crashes when updating linked files
          FergyMac Level 3
          Fixed it!
          I removed the scripts I had added over the years and it no longer crashed when updating links . . . for one try. Then I replaced my preferences again and it seems to have returned to normal operation.
          So, if replacing your preferences doesn't fix the problem, try removing all the extra enhancements you've added and replace your preferences again.
