5 Replies Latest reply on Dec 15, 2016 1:27 PM by Jerome Raim
    Editing a Title (.prtl) file
    Kelly Anderson Level 1
      Hello,
      I'm trying to edit an exported title file from PPro.  The editing is working but when I import the file back into PPro, PPro crashes.
      I've tried writing the file as UTF8 and UTF16.  Both crash PPro.  Any ideas?
      thanks,
      Kelly
      Here's my code:
      var tapeType = "<TRString>TAPE TYPE</TRString>";
      var theFile = File("/Users/ops.kanderson/Desktop/OnAir Slate.prtl");
      theFile.open ("r");
      var theText = theFile.read();
      theFile.close();
      theText = theText.replace (tapeType, "<TRString>GENERIC MASTER</TRString>");
      var outFileName = 'kellySlateText1' + '.prtl';
      var completeOutputPath = "/Users/ops.kanderson/Desktop/" + outFileName;
      var outFile = new File(completeOutputPath);
      if (outFile){
        outFile.encoding = "UTF8";  OR outFile.encoding = "UTF16";
        outFile.open("w", "TEXT", "????");
        outFile.write(theText);
        outFile.close();
        • 1. Re: Editing a Title (.prtl) file
          Bruce Bullis Adobe Employee
          What encoding does [your favorite text editor] say the .prtl is written with, BEFORE your changes?
          • 2. Re: Editing a Title (.prtl) file
            In my research, TextEdit says the file is UTF-16.  Textwrangler and BBEdit say UTF-16 Little Endian.  The Mac terminal says UTF-16 Little Endian.  So I changed my code to be UTF16LE and the file still crashes PPro.
            if (outFile){
              outFile.encoding = "UTF16LE";
              outFile.close();
            • 3. Re: Editing a Title (.prtl) file
              I'm still working on this issue.
              I still cannot export a .prtl then edit the file in a text editor and re-import the file into PPro without PPro crashing.
              Are there any known specs for a .prtl file?
              Is anyone working with this same workflow?
              thanks,
              Kelly
              • 4. Re: Editing a Title (.prtl) file
                There are no specs; it's not a documented or supported format.
                Best approach to automagically updating titles, today = do the titles in AE, and send AE ExtendScript from a PPro panel (yep, it's possible) to make those changes.
                Getting/setting the text from PPro's titles is high on the API request list.
                • 5. Re: Editing a Title (.prtl) file
                  Jerome Raim Level 1
                  Despite the PRTL claiming to be UTF-16, I think it's actually encoded as UTF-8.
                  I managed to modify a PRTL in TextWrangler and import into Premiere without it crashing by:
                  Copy-pasting the XML data into an empty document. TextWrangler auto-detects it as UTF-16. I manually change it to UTF-8 (but do not touch the XML declaration  <?xml version="1.0" encoding="UTF-16" ?>).
                  When I save this as a PRTL, TextWrangler warns me about "Document encoding mismatch." but I save it anyway.
                  Premiere imports the PRTL without crashing.
