• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to disable text wrapping on text boxes?
New Here ,
Sep 27, 2016 Sep 27, 2016
whenever I create a new text box, there is automatically a 1p0 text wrap around it.  how do I disable this from happening? thanks
TOPICS
How to
Views
48.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Sep 28, 2016 Sep 28, 2016
I'm not clear from the wording if this is happening in one file, or all new files. Clearly text wrap was turned on as a default, but it could be in one file (a document default) or for all new files (a system default).
This article should clarify the two, and give you the skills to disable one or both.
Adobe InDesign: Setting (and Removing) Defaults - Rocky Mountain Training
Once you understand the difference, you can disable it correctly with Window > Text Wrap a
Votes
Translate
Translate
Community Expert ,
Select the (text) frame and go to Window > Wrap and click on the none-button.
But you should work with Object Styles and make sure that your default styles have no text wrap upon them. Default styles are those with one of the two small icons on the right.
To avoid text wrap for a single text frame go to Object > Text Frame Options (or in the context menu or cmd/ctrl+B) and activate to ignore text wrap. Save this also in the Object Styles.
Votes
Translate
Translate
Report
Report
Enthusiast ,
This is a simple one to do it. Start up your Indesign but do not open any document or new document, just click on the text box in the toolbar and press Ctrl+Alt+W (Text wrap), a text wrap dialog box will appear on that set to none (no text wrap). Now open up a new document and see is it disable or not.
Votes
Translate
Translate
Report
Report
Community Expert ,
Once you understand the difference, you can disable it correctly with Window > Text Wrap and clicking the first button on the top row.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Aug 17, 2018 Aug 17, 2018
I have tried all these things and all the text box wrap is turned off and I said ignore text wrap in the text frame options and nothing works everytime I move a text box it will jump all over the place like the wrap is on it is super annoying and this is making my spacing all f'ed up.   I also turned off snap so that not it either.
Votes
Translate
Translate
Report
Report
Community Expert ,
Sounds like Align to Baseline Grid. This is a paragraph setting.
Votes
Translate
Translate
Report
Report
Aug 10, 2021 Aug 10, 2021
This is the the (partial) answer. It kept wrap-
ping like this and I didn't know how t-
o turn it off.
I expanded the Paragraph setting (3 dots '...') and Hyphenate was checkmarked. I unchecked it and the wrapping disappeared! Thanks so much SJ!
Votes
Translate
Translate
Report
Report
Community Expert ,
Can you post some screenshots? While I'm leaning toward the baseline grid as well, those screenshots would help.
Votes
Translate
Translate
Report
Report
Community Expert ,
One of the screenshot should be of the Text Wrap panel with nothing selected.
A second should be the View Options controls so we can see what is checked. “View Options” is one of the three buttons on the Control panel that you see when you have the Selection tool.
Votes
Translate
Translate
Report
Report
Community Expert ,
Where do you see the setting that says your new text frames have a 1p0 text wrap?
Votes
Translate
Translate
Report
Report
Enthusiast ,
Aug 22, 2018 Aug 22, 2018
Is this for all new documents or existing ones? Whether it's a text wrap or baseline issue, you have to figure out where the default is (all new docs or a current doc?). If all new ones are doing it, as said above, you need to reset it with no document open. If it's just a specific file or files, then reset with no object selected with the specific file open.
Votes
Translate
Translate
Report
Report
New Here ,
Jul 12, 2023 Jul 12, 2023
Literally none of this worked, and I can't get it to stop. I cannot select anything in the text wrapping before I open documents for defaults, and it doesn't allow me to change those settings once I've opened a new document. Does anyone have any idea? I'm working on a Mac.
Votes
Translate
Translate
Report
Report
New Here ,
Jan 22, 2024 Jan 22, 2024
LATEST
I was having this problem as well and the below worked for me. It was happening in just one of my documents. This is from the link provided above .Adobe InDesign: Setting (and Removing) Defaults - Rocky Mountain Training Thanks!
  1. Open up an InDesign document. ( I opened the one giving me problems)
  2. Click the Selection Tool in the Toolbox (the black arrow).
  3. Click on an empty part of the page or better still, choose Edit > Deselect All.
  4. Without any objects selected, take a look at the various menus and panel menus. Any choices you make in the menus without an object selected will change the defaults for this one file.
  5. Take some time to look at what’s available and pick your favorite settings, or remove a setting that you activate inadvertently.
Votes
Translate
Translate
Report
Report
