11 Replies Latest reply on Sep 29, 2016 4:07 AM by Suzan.V
    change in locked stories (GREP)
    Suzan.V Level 1
      Hi all,
      i'm seeking a way to do change in all locked stories without need to unlock them.
      i tried a lot in scripting but i only found a way to change in hidden layers not locked stories or text frame
      is it possible to do in scripting because i found it possible but on apple coding
      Suzan
        • 1. Re: change in locked stories (GREP)
          tpk1982 Level 4
          I hope you included in this lines before find and change (if you usie Grep search)
          app.findChangeGrepOptions.includeLockedStoriesForFind = true;
          • 2. Re: change in locked stories (GREP)
            Suzan.V Level 1
            well, i used your advice as shown on below code but still no thing changed on locked layers (stories)
            main();
            function main() {
                var doc = app.activeDocument;
                app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.NOTHING;
                 app.changeGrepPreferences.appliedFont = "Arial";
                app.findGrepPreferences.fontStyle = "Regular";
                app.changeGrepPreferences.appliedFont = "Myriad Pro";
                app.changeGrepPreferences.fontStyle = "Bold";
                doc.changeGrep();
            • 3. Re: change in locked stories (GREP)
              milligramme Level 3
              Hi
              try of locked layer
              .includeLockedLayersForFind
              You can only find in locked stories and layers, to change you should unlock stories (from InCopy?) or layers.
              thankyou
              mg.
              • 4. Re: change in locked stories (GREP)
                tpk1982 Level 4
                try this..
                main();
                function main() {
                  app.findChangeGrepOption.includeLockedLayersForFind = true;
                     app.findGrepPreferences.appliedFont = "Arial";
                    doc.changeGrep();
                • 5. Re: change in locked stories (GREP)
                  Suzan.V Level 1
                  milligramme wrote:
                  Hi
                  try of locked layer
                  thankyou
                  mg.
                  i tried both lines but no thing changed, this means that there is no way to change text inside locked stories or layers and i have to unlock it first ??
                  Suzan
                  • 6. Re: change in locked stories (GREP)
                    milligramme Level 3
                    Generally using `[target].changeGrep()` won't work.
                    I found another way, this work for me (cc version9.3) without unlocking textframes and layers.
                    main();
                    function main() {
                      var find_grep_obj = {
                        appliedFont: "Arial",
                        fontStyle: "Regular",
                      var change_grep_obj = {
                        appliedFont: "Myriad Pro",
                        fontStyle: "Bold",
                      with (app.findChangeGrepOptions) {
                        // includeFootnotes            = false;
                        // includeHiddenLayers         = false;
                        // includeLockedStoriesForFind = true;
                        // includeMasterPages          = false;
                        // kanaSensitive               = true;
                        // widthSensitive              = true;
                      var match = grep_find(doc, find_grep_obj);
                      for (var mi=0, mlen=match.length; mi < mlen ; mi++) {
                        var container = match[i].parentStory.textContainers;
                        for (var ti=0, tlen=container.length; ti < tlen ; ti++) {
                          // without unlocking
                          // container[ti].locked = false;
                          // container[ti].itemLayer.locked = false;
                        for (var prop in change_grep_obj) {
                          match[mi][prop] = change_grep_obj[prop];
                      function grep_find (target_obj, find_grep_obj) {
                        app.findGrepPreferences = NothingEnum.nothing;
                        app.findGrepPreferences.properties = find_grep_obj;
                        var result = target_obj.findGrep();
                        return result;
                    thank you
                    mg.
                    • 7. Re: change in locked stories (GREP)
                      Suzan.V Level 1
                      i got this error and no thing changed
                      • 8. Re: change in locked stories (GREP)
                        tpk1982 Level 4
                          use this..
                        app.findChangeGrepOptions.includeLockedLayersForFind = true;
                        "s" missing in findChangeGrepOptions
                        • 9. Re: change in locked stories (GREP)
                          Suzan.V Level 1
                          unfortunately same result
                          did that code work for you? i'm afraid that  may be my application or file is corrupted..
                          sorry for bothering you again and again.
                          Suzan
                          • 10. Re: change in locked stories (GREP)
                            Suzan.V Level 1
                            Dear mg, thanks a lot my dear works perfect and awesome
                            many thanks again for your help and time..
                            cheers
                            Suzan
