4 Replies Latest reply on Sep 29, 2016 8:03 AM by maria__
    23.0.0.162 installer crashes on Windows 7
    Glasgow29980493
      Hi
      I'm trying to publish the new version over our LAN, and am following my normal procedures...
      • download the exe installers and uninstaller
      • run the uninstaller silently with the -uninstall switch
      • run the installers silently with the -install switch.
      I've downloaded the latest exe installers (and uninstaller).
      However, the uninstaller and installers crash when I try to run them (example here is the uninstaller):
      The text in the error:
      Problem signature:
        Problem Event Name: APPCRASH
        Application Name: uninstall_flash_player.exe
        Application Version: 23.0.0.162
        Application Timestamp: 57c4cc94
        Fault Module Name: KERNELBASE.dll
        Fault Module Version: 6.1.7601.23392
        Fault Module Timestamp: 56eb2fb9
        Exception Code: c000008f
        Exception Offset: 0000845d
        OS Version: 6.1.7601.2.1.0.256.48
        Locale ID: 2057
        Additional Information 1: 0a9e
        Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
        Additional Information 3: 0a9e
        Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
      I'm running this on Windows 7 PCs (32 bit). The previous version - 22.0.0.209/210 - still works fine (no errors).
      I've found that if I manually remove all Flash player files from a PC (ie %systemroot%\system32\macromed, and %appdata%\Adobe\Flash Player, and %appdata%\Macromedia\Flash Player), then the first run of either installer, or the uninstaller, seems to run OK. However, subsequent attempts to run any of the files, or to view Flash in IE, all crash out with an identical AppCrash error to the one above.
      Anything else I can try?
      Thanks!
        • 1. Re: 23.0.0.162 installer crashes on Windows 7
          maria__ Adobe Employee
          I'm not able to reproduce the behaviour, however, have forwarded the information to the installer engineer for further investigation.
          Maria
          • 2. Re: 23.0.0.162 installer crashes on Windows 7
            We'd like to get the crash dump files from you to investigate further. Crash dump logging is not enabled by default.  Please follow the instructions at Collecting User-Mode Dumps (Windows)  to enable crash dump logging.  For DumptType use option 2 - Full Dump.  Repeat the behaviour that results in the crash.  In the crash window, click 'View Details' to obtain the location of the files generated.  Obtain all files listed in the crash window details panel and upload them t to cloud.acrobat.com/send using the instructions at How to share a file using Adobe Document Cloud.  Post the link to the uploaded file in your reply.
            Thank you.
            Maria
            • 3. Re: 23.0.0.162 installer crashes on Windows 7
              Glasgow29980493 Level 1
              Hi Maria
              I've uploaded a dump file for your investigatory pleasure. Linky
              However - I think I have found the issue. I found a laptop that wasn't experiencing the crashes and compared the list of installed items on it against the installed items on one of the failing desktops. This led me to a utility we use called DDinterceptor (D&D Interceptor). It's a small utility that pops up a confirmation message when users try to drag files in Windows (in an attempt to combat the regular rearranging of networked folders that our users enjoy so much). We've had it installed for years so it didn't spring to mind as a possible culprit.
              Long story short - with DDinterceptor uninstalled the problem goes away, and the 23.0.0.162 installers / uninstaller run without issue.
              Something's presumably changed in the Flash installers that's managing to trigger the confirmation message. Any chance of getting the installers changed so that the new behaviour is removed and they play nicely with the utility (ever the optimist)? In the meantime I'll script a way of disabling our utility before I run the Flash updates.
              Thanks for your input!
              • 4. Re: 23.0.0.162 installer crashes on Windows 7
                Hi Glasgow29980493 ,
                Thank you for providing the log files and the additional information on the D&D Interceptor utility.  I'm not familiar with that tool.  I will forward the log files and the D&D Interceptor tool to our installer engineer for further investigation.
                We recently made some changes to the installers to address security vulnerabilities, but they were made prior to the latest release.  Since these were security-related changes they won't be rolled back.
