Hey team,
Every time I try to preview my project in Captivate 9, the screen will appear zoomed in (this occurs for all levels of previewing), however, if I publish it and then watch it, this does not occur. So the problem exists only in the preview. Is anyone else having this problem and found a fix to the solution? Would really appreciate your help on this one as it is extremely frustrating.
Thanks team.
First, Check your browsers zoom settings.
When you publish, are you viewing from a webserver or via the local file structure?
Hey BDuckWorks,
Thank you for you fast reply. When I publish currently I am viewing via web browser by clicking on 'view finoahed product' when the publishing is done (as I dont want to yet upload it to the LMS which is cloud hosted), and that seems to be ok. my project is a screen simulation set to HD but also scalable. I'll check my xoom settings in browser today just incase though for future reference. 🙂
Which Preview methods did you use: if you use in Browser or HTML in Browser it can be the zoom percentage indeed. If this is a normal project, the other methods do not use a browser but if you are in a responsive project, all is happening in a browser as well.
Hey Lilybiri,
Thankyou for your fast response 🙂 Really appreciate it. Im using a screen simulation set to HD resolution but ticked the scalable option so it suits all screen resolutions. I am previewing it inside captivate using the 'preview project' or 'preview next 5 slides' or 'preview in web browser' options but they are all doing the same thing (zooming in without being able to change it). If I publish it and view the output in a browser, its fine, but that takes considerably more time to just view one slide to check my work as I go. I was hoping there is a fix for this one as I absolutely looooove Captivate in all its complexity and have been using it since 6.0 (also following your blogs since then so thanks for those), however this is a slightly frustrating and unusual event. Any help would be much appreciated. 🙂
I'm having this problem...did you ever get it fixed? If so, how?! Thanks so much.
Are you also talking about a simulation?
Not a simulation, per se. It is a combination of slides and video I will publish to a big video. When I publish it, the resolution is fine. But when I try to preview it...Preview Project, Preview next 5 slides, etc...it is so zoomed in I can't proof it. I've checked the zoom on every browser and they are all fine. Any suggestions? thanks.
I rarely use Preview methods except Preview in Browser or Preview HTML in Browser for non-responsive projects. I suppose it is such a project. That is a strange phenomenon, because normally the other previews would be following the display % of the screen and since you don't speak about problems with Captivae itself. Which resolution do you have for the project? What is the display % for the used screen?
