I created a flash file contained 2 scenes, "Wheel_Slide_In" and "Wheel_Rotate". mu goal is to play scene "Wheel_Rotate" after "Wheel_Slide_In" finish playing.
I put this code in the last frame of "Wheel_Slide_In" :
//gotoAndPlay(1,"Wheel_Rotate");
//gotoAndStop(1,"Wheel_Rotate");
//MovieClip(parent).gotoAndPlay(1, "Wheel_Rotate");
and many many othe random! combinations with parent and root to tell the flash this simple task!
Hey dear Flash, please play "Wheel_Rotate" Scene after "Wheel_Slide_In" Scene! Simplz!
unfortunately, me and Flash don't talk the same language!
could you please help me to write the correct code and understand how you play another scene from a different one?
many thanks
If the code is in the main timeline then gotoAndPlay(1, "Wheel_Rotate"); should work
You should avoid using scenes and either use movieclips or have it all in one scene. Scene navigation has always been an issue with Actionscript/Flash.
