This content has been marked as final.
Show 3 replies
1. Re: fetch xml and fill datas in Array
Newsgroup_User Feb 26, 2009 6:21 AM (in response to rahimhaji)
"rahimhaji" <webforumsuser@macromedia.com> wrote in message
news:go5gq7$bjq$1@forums.macromedia.com...
> Dear Friends,
> i am working on a flex stand alone ticker. i want to connect and fetch a
> xml
> data (generated by php), and those data has to store in an array or array
> collection. i will connect this array to a repeater tag as dataprovider.
> kindly tell me how to fill the array with data fetched from a xml. i got
> struct up.. i have to finish my project.. iam in pressure pls..
http://www.magnoliamultimedia.com/flex_examples/Amys_Flex_FAQ.pdf
Q1
2. Re: fetch xml and fill datas in Array
Gregory Lafrance Feb 26, 2009 9:35 AM (in response to Newsgroup_User)You will have to modify this a bit, for example resultFormat="array" if your data is an array, "e4x" for xml. resultHandler() code will likely change as well. -
3. Re: fetch xml and fill datas in Array
rahimhaji Mar 1, 2009 12:13 AM (in response to Gregory Lafrance)Dear Mr.Greg Lafrance,
Thaks a lot, this code is working fine. i tried to change this labels in to check box. that too working it created the check boxes. but i have the following difficulties:
1) it creates check boxes. it shows the label only for first item, other i items the label shows empty.
for adding check box i gave the following code:
<mx:CheckBox id="chk" label="{rp.currentItem}" color="{count++ % 2?0xFF0000:0x00FF00}" height="100" width="200"/>
i can see the checkboxes in horizontal order without labels. pls tell me how can i bring the labels for entire checkboxes.
2) if i click on the created text boxex, i need to fetch the label of the text box or index of the text box will it possible pls tel me the possible way. for that i gave the following code, but it gives the error:
click="trace(chk.label)"
kindly help me to do these things. i need to fetch the index of the check box atleast.
Thanks and regards,
Syed Abdul Rahim
