0 Replies Latest reply on Feb 26, 2009 3:19 AM by gastverh
    Linux FC10 Adobe Flash 10 Print problem
    gastverh Level 1
      Hello,
      In Linux FC10, I cannot successfully print a Flash-document on my Epson Stylus D120 Printer.
      For instance, on the following site, with the right mouse button, I am able to make a print the map.
      www.plattegronden.nl/bergenopzoom
      Then you will see a map, which is an Adobe Flash Player 10 document, which is installed:
      Arch : i386
      Version : 10.0.22.87
      The print copy is printed with big steps in a big speed, so the result is a low resolution with black matrix points, and bad readable.
      Trying to solve the problem, I did search more printer configurations, e.g. in
      http:////localhost:631/ CUPS
      but not successfully.
      Hoping the problem is clear and good understandable.
      Many thanks in advance for each answer,
      Greetings,
      Gaston Verhulst.
