5 Replies Latest reply on Sep 30, 2016 12:09 AM by alsop89
    Make a work path from selection
    alsop89
      Hi, I'm trying to figure out how to make a work path from a selection, I'm using a small script to test it out on, where I have a test file that has a selection made. I need to make it a work path (and eventually a clipping path) but I can't seem to do it
      I'm working in applescript but I'm not adverse to adding in a bit of java as a variable
      can someone make this work?
      Cheers
                          tell application "Adobe Photoshop CC 2014"
                                      tell current document
                                                     make work path with selection
                                      end tell
                                    end tell
        • 1. Re: Make a work path from selection
          SuperMerlin Level 5
          In javaScript:-
          app.activeDocument.selection.makeWorkPath();
          2 people found this helpful
          • 2. Re: Make a work path from selection
            greenrookie Level 3
            In Applescript:
            tell application " Adobe Photoshop CC 2014"
                                  tell selection
                                             make work path tolerance 2 # tolerance in pixels
                                  end tell
                       end tell
            end tell
            • 3. Re: Make a work path from selection
              natrev Level 3
              Try this..
              // Work path Tolerance set
              app.activeDocument.selection.makeWorkPath(0.5);
              // Clipping path flatness set
              var pathitem=app.activeDocument.pathItems.getByName ('Work Path');
              pathitem.name="Path 1";
              app.activeDocument.pathItems[0].makeClippingPath(0.2);
              pathitem.deselect();
              -yajiv
              • 4. Re: Make a work path from selection
                greenrookie Level 3
                In Applescript:
                                             tell selection
                                                           make work path tolerance 2 #in pixels
                                             end tell
                                             set workPath to path item "Work Path"
                                             set name of workPath to "Path 1"
                                             tell path item 1
                                                           make clipping path flatness 2
                                                           deselect
                                             end tell
                              end tell
                end tell
                • 5. Re: Make a work path from selection
                  alsop89 Level 1
                  You absolute champ!
