2 Replies Latest reply on Mar 2, 2009 11:21 AM by BillyB13
    Need help with Customize Window No Chrome
    combustion007
      Hello Everyone,
      I am trying to learn to do system chrome less window and having issues. I am almost there but having issue with aligning the window to the center and window close events. Can anyone point me to where am I going wrong. Here is my code:
        • 1. Re: Need help with Customize Window No Chrome
          BillyB13
          I can help you on the chrome part:
          Add this to the Windowed Application line:
          showFlexChrome="false"
          horizontalScrollPolicy="off"
          verticalScrollPolicy="off"
          Edit the <yourApplicationName>.xml file (under source) and change the following 2 lines:
          <!-- The type of system chrome to use (either "standard" or "none"). Optional. Default standard. -->
          <systemChrome>none</systemChrome>
          <!-- Whether the window is transparent. Only applicable when systemChrome is none. Optional. Default false. -->
          <transparent>true</transparent>
          good luck.
          billy b
          • 2. Re: Need help with Customize Window No Chrome
            BillyB13 Level 1
            worked on the close window issue also. My quick clean up of your version.
            Note that i used the "click" on the button and dumped the event.
